Is there any way to configure a PTP-600 connectorized unit to use only one polarization?
ie the link only uses vertical and a single feed antenna.
Hi Matt
Yes there is, but its not a customer accessible setting.
Our technical support team will be able to help - I will raise a case for you.
Regards
Julian
