Summary/Cause:
The PTP 800 is End of Sales product, and the parts/accessories may not be available for purchase.
If the PN WB3807, PTP 800 1 + 1 out of band splitter is found faulty then there is no replacement or alternate device available.
Solution:
We can use special pinouts and create a H-Cable that can be used in place of splitter for connection between 2 PTP 800 IDU/CMU and the network devices and restore the services.
Below are the pinouts for H-Cable:
| LAN 1 | CMU 1 | LAN 2 | CMU 2 | CMU 1 | CMU 2 | ||
| 1 | 1 | 1 | 1 | 1 | NC | ||
| 2 | 2 | 2 | 2 | 2 | NC | ||
| 3 | 3 | 3 | 3 | 3 | NC | ||
| 4 | NC | 4 | NC | 4 | 7 | ||
| 5 | NC | 5 | NC | 5 | 8 | ||
| 6 | 6 | 6 | 6 | 6 | NC | ||
| 7 | NC | 7 | NC | 7 | 4 | ||
| 8 | NC | 8 | NC | 8 | 5 |
Refer below diagram for more simplified connection/pinouts for H-Cable:
