allenyu
(Allen Yu (inactive))
September 26, 2019, 3:25pm
#1
We are glad to report that PTP 820 Release 10.9 and PTP 820 NMS R18A000 is available under support web page
https://support.cambiumnetworks.com/files/ptp820/
Following are the main new features introduced in release 10.9. The highlights are
Advanced Spatial Diversity supported in PTP 820C and PTP 820C HP
Eliminate one antenna, only three antenna is required
25% saving on OPEX and CAPEX
3dB and 6dB increase on system gain
Remote tower space limitations
2048 QAM support on 80 MHz for PTP 820S and PTP 820C, PTP 820C HP
6% throughput increase compare to 1024 QAM
Without compression, single carrier can support 679 – 829 Mbps depends on frame size.
Quick Configuration Wizard for 2 x (1+0)
Customer can setup a 2+0 without MC-ABC using installation wizard.
Here is a summary for new features, details can be found from release notes:
AnzeZ
(AnzeZ)
October 1, 2019, 6:21am
#2
We have NMS version 15, could we upgrade to 18 version with the same license? Probably support should generate us a new license for new version, but is it possible to do it without buying new license, just because of new NMS version?
Thank you.
allenyu
October 1, 2019, 8:00pm
#3
The license key has no dependancy on software release. You can upgrade the system without need a new license.
Regards
Allen
SF_Carney
(SF Carney)
October 14, 2019, 3:09pm
#5
Thank you.
re: PTP820G. Has this version release received FIPS140-2 certifcation? If not, what is the target date for compliance? Thank you.
allenyu
October 14, 2019, 9:28pm
#6
This release is NOT FIPS140-2 validated. Our next FIPS-140 validated release will be 1H 2020.
