Many of you would like to stage your links before you deploy them.
This allows you to configure the radio and Ethernet services to ensure they are working properly--it's a lot easier to do this on the bench than on the tower!
I've attached a spreadsheet with the full set of data for PTP 820S, PTP 820C, and PTP 820G for 6, 7/8, 10/11, 13, 15, and 18 GHz.
The "BOMs" tab has a full BOM for 6, 11, and 18 GHz.
The "overall" tab shows additional part numbers for 7/8, 10, 13, and 15 GHz links.
I hope this helps!
Dave
