Hi, anyone who can suggest me my PTP links are ok?
- PTP Link Planner for Site.zip (2.1 KB)
Hi Zwe,
The links look fine to me. Of course, you have to verify LOS and interference via site surveys. LINKPlanner is assuming -88dBm interference in 40MHz channels. If interference is different from assumed values in the clean channels you're able to identify and configure the links for then your throughput will also be impacted. How much throughput do you need? Is the predicted throughput sufficient?
