PTP650 Rebooting while not registration and switch off the POE on AUX port.
Is possible to change timeout or disable rebooting if no registration?
At present there is no way to disable the registration timeout or to change the period. Can you explain the application in a bit more detail? We might be able to help.
We power via AUX port POE Access Point MESH (Motorola) which can send traffic via Cambium or via MESH. But if POE power of while restarting - it's break MESH network.
Can you help in this issue?
