PTP670 HTTPS access!
Hi All,
How to enable PTP670 https access ?
Hi All,
Any help here !
Maybe try reading the manual?
https://support.cambiumnetworks.com/files/ptp670/
Thats a great support from you !
Thank you very much.
I wish I get a similar helpful response for any future request.
It appears with the PTP670 latest current version if you review what they are calling the “Cambium PTP 670 Series 04-10 User Guide” in it there is a system planning chapter, chapter 3, and if you search for “Planning for HTTPS/TLS operation” you should find important planning information. Then, they also have a configuration and alignment chapter and if you search for “Enter HTTPS Configuration” you should find more important information. I searched this particular user guide for “https” which helped isolate relevant parts.
