Hi all in the community.
I have a doubt about if the SFP in the PTP670 (multimode or monomode version) can be used to connect directly to the Cisco Switches SFP connector., and if I will have compatibility issues.
For example:
I have a CN SFP multimode connected to a Cisco SFP multimode on a switch, Is this valid and no issues?
I have a CN SFP multimode connected to a CN SFP multimode installed in a Cisco Switch. Is this valid and no issues?
Both sides uses Cisco’s SFP (PTP670 and Cisco Switches using its). Is this valid and no issues?
Do I need a license in the PTP670 to enable the SFP operation?
So, could the community help me with yours experience how to connect this topology to a Cisco Backbone Switches with out no issues, Do I have to buy specials SFP or inclusive the Cisco SFP are fine to do this?
My best regards and thank you to all.
