Hello,
I have two ptp810 MMUs with fan failure alarms. I have a couple of questions I hope you could help me answer:
- Is this fault field solvable?
- If yes, what would be the correct procedure: can I buy replacement fans or should I get a new MMU Controller Card?
Thank you in advance for your help.
Sincerely,
Roberto Currlin
Telesis, SA de CV
San Salvador, El Salvador
