PTP820 extra items Dimensions and Weights
Hey
I am looking at getting some tower cerfication performed to confirm we can hang the desired gear up the communications towers.
I am unable to find any real information on anything other the they weight and dimension of the outdoor unit and antenna. I am unable to find weight and dimensions for the following.
Cambium N000082L061A PTP 820C MIMO or Prot management cable 1m
Cambium N000082L062A PTP 820C MIMO or Prot management odu spltr
Cambium N230082D023 PTP 820 2' ANT,SP,23GHz,RFU-C TYPE&Std UBR220 - Andrew
Cambium N230082L032 PTP 820C DUAL COUPLER KIT 23GHz
Cambium N230082L034 PTP 820C OMT KIT 23GHz
Cambium N230082L039 PTP 820 RFU-C 23GHz OMT Interface-Andrew
Cambium N110082D072 PTP 820 2' ANT,SP,11GHz,RFU-C TYPE&Std UBR100 - Andrew
Cambium N110082L080 PTP 820C DUAL COUPLER KIT 10-11GHz
Cambium N110082L082 PTP 820C OMT KIT 10-11GHz
Cambium N110082L092 PTP 820 RFU-C 10_11GHz OMT Interface-Andrew
If anyone knows where I can obatin this that would be great
P/N Description  Packed
Weight (kg)
Shipping Dimensions
 LxWxH (cm)
N000082L061A PTP 820C MIMO or Prot management cable 1m 0.5 10x25x25
N000082L062A PTP 820C MIMO or Prot management odu spltr 0.05 20x7x20
N230082D023a PTP 820 2' ANT,SP,23GHz,RFU-C TYPE&Std UBR220 - Andrew 10.9 36x73x69
N230082L032a PTP 820C DUAL COUPLER KIT 23GHz 5.8 32x38x32
N230082L034a PTP 820C OMT KIT 23GHz 3 18x30x29
N230082L039a PTP 820 RFU-C 23GHz OMT Interface-Andrew 2.5 28x18x28
N110082D072a PTP 820 2' ANT,SP,10_11GHz,RFU-C TYPE&Std UBR100 - Andrew 19.42 70x70x56
N110082L080a PTP 820C DUAL COUPLER KIT 10-11GHz 2 31x31x34.2
N110082L082a PTP 820C OMT KIT 10-11GHz 2.9 19x33x28
N110082L092a PTP 820 RFU-C 10_11GHz OMT Interface-Andrew 2.5 18x28x28
Can I use the same dimensions for the L6GHz OMT, also L correspond to the depth?
