Hi. I have a question about PTP820 capacity licences.
Let's say that customer has 100M license on a link and would like to upgrade to 300M/500M. To do that, customer has to buy license for 300/500M, not just the upgrade from X to 300/500M? I was thinking that the license should be cheaper to upgrade from X to 300/500M than a license for whole 300/500M capacity?
We have simplified our PTP820 capacity keys and just have the following now - 100/500/650 Mbps as well as upgades from X to 500/650 Mbps. You can get pricing from your VAR or disty. It looks like the MSRP for the 500/650 Mbps keys are priced identically to the upgrades from X to 500/650 Mbps keys so you might as well buy the maximum capacity key if you think you'll need it.
N000082L032A
PTP 820S Act.Key - Capacity 100M with ACM Enabled, per Tx Chan
N000082L033A
PTP 820S Act.Key - Capacity 500M with ACM Enabled, per Tx Chan
N000082L034A
PTP 820S Act.Key - Capacity 650M with ACM Enabled, per Tx Chan
N000082L035A
PTP 820S Act.Key - Capacity upgrade from X to 500M, per Tx Chan
N000082L036A
PTP 820S Act.Key - Capacity upgrade from X to 650M, per Tx Chan
N000082L077A
PTP 820C Act.Key - Capacity 200M with ACM Enabled, per Tx Chan
N000082L078A
PTP 820C Act.Key - Capacity 500M with ACM Enabled, per Tx Chan
N000082L079A
PTP 820C Act.Key - Capacity 650M with ACM Enabled, per Tx Chan
N000082L080A
PTP 820C Act.Key - Capacity upgrade from X to 650M, per Tx Chan
N000082L081A
PTP 820C Act.Key - Capacity upgrade from X to 500M, per Tx Chan
N000082L082A
PTP 820G Act.Key - Capacity 100M with ACM Enabled, per Tx Chan
N000082L083A
PTP 820G Act.Key - Capacity 500M with ACM Enabled, per Tx Chan
N000082L084A
PTP 820G Act.Key - Capacity 650M with ACM Enabled
N000082L085A
PTP 820G Act.Key - Capacity upgrade from 100 to 650M, per carrier
N000082L086A
PTP 820G Act.Key - Capacity upgrade from X to 500M, per Tx Chan
N000082L127A
PTP 820S Act.Key - Capacity 200M with ACM Enabled, per Tx Chan
N000082L129A
PTP 820S Act.Key - Capacity 300M with ACM Enabled, per Tx Chan
N000082L130A
PTP 820C Act.Key - Capacity 300M with ACM Enabled, per Tx Chan
N000082L131A
PTP 820G Act.Key - Capacity 200M with ACM Enabled, per Tx Chan
