PTP850S Protection Cable
Does anyone have the pinout for the miniDP to RJ45 protection cable used for the PTP850S? We’ve got a radio someone completely goofed up the config on we need to reset. I can try to order the cable if we have to, but we are in a time crunch to get this fixed. I have everything here to make a cable.
In the event anyone else runs into this, support has the pinout and was able to send it to us. We used a miniDP to DP converter and a DP to terminal block breakout to assemble the cable. Worked great.
