Hello how are you friend cambium forum, Greetings from wireless jadingan technicians from Jakarta Indonesia, at the moment I'm trying to cnPilot E400 wifi in my workplace.
The test results for the 5GHz 100Mbps ethernet status results of wifi speed can reach 90Mbps result is quite okay and is in stable hopefully the current monitoring.
We are suggesting cnPilot E400 the best configuration if the configuration is correct that I use and I look forward to hearing his sharing of this forum Thanks a lot in advance.
For example configuration here Setting Wifi Cambium cnPilot E400
