We have many, many, r200p routers in the field and every single one has come out of the box with "allow wireless host" enabled. For some reason, the 150 r190 units we just ordred do not have this setting enabled out of the box. When you are trying to push mass config file updates or even log in to change wifi settings, it adds so much time having to lan cable in to each device instead of going in via wifi like every other cn pilot router we have purchased. Please do not say the fix for this is CN Maestro.
