We are also seeing the config failed error for [max_radios]. We have tried 4.7.5-R2 and every firmware down to 4.7.2-R10.
This isn’t a firmware issue. CnMestro is pushing a value that the radio’s don’t know about. Attempted to run a config from template vs AP group and same error happens even though there is no [max_radios] value in the template.
@anthonyw This is indeed a firmware issue that was fixed in 4.7.5-R2.
Please download tech support file from cnMaestro and share with us, we shall investigate the issue.
This issue has been resolved with a beta firmware.
After installation you can downgrade and upgrade the unit again. At this point we have not seen the issue re-appear on “fixed” units. But it has only been a week or so. I suspect the core issue is sitting in a firmware between 4.7.3-R21 and 4.7.5-R2.
I say this because we did not have this issue when widely installed on hundreds of devices 4.7.2-R10 for a significate amount of time. Issue started after upgrade to 4.7.5-R2 / CnMestro upgrade to 3.1.1
I just had this same problem on an R195W. The customer defaulted their router, so I tried to sync config and received the “Invalid field [max_radios], please check” message.
Router was already on 4.7.5, then downgraded to 4.7.1 (Since cnMaestro still recommends this version), then upgraded back to 4.7.5 after finding this thread.
