R201 Matching SSID For 2.4 and 5 GHz Bands?
The R201 defaults has a different SSID for the 2.4 GHz and 5 GHz bands. I have run it with matching SSIDs as a limited test without issues so far.
Are there any known issues with the R200 running matching SSIDs on the two bands?
Thank you,
Chris
Hi Chris,
There no problem in setting the same SSID on both the radios. And it works  well.
thanks
Ashutosh
