With the latest Firmware Version installed - 4.8.1-R4(202301111440) - how can one disable HTTP access on the Web Access Protocol Interface selection box, to allow the router to be accessed by HTTPS?
With the latest firmware , there are only two options to select as Web Access Protocol: HTTP and HTTPS.
With earlier firmware, you used to be able to select HTTP, HTTPS or both, as I recall.
