Recently my epmp radio device has experienced an unusual thing That was struck by lightning Causing damage to the epmp radio When i want to replace with the radio beru The strange thing is when I want to connect with the antenna suddenly the radio immediately died, but if I move away with the radio antenna lights up
How yes this can happen I beg for his help thank you
So is the same radio that was hit by lightning, the one that dies when connected to theĀ antenna? Or is a new replacement radio the one that dies when connected to the antenna?
Even if the radio that was hit by lightning is powering on, there is a high probability that it has been damaged. If it is the new replacement radio that is dying when connected to the antenna, have you tried a different antenna?
I use a new radio and die when connected with an antenna Yes ,, and i have tried to use another antenna I use ePMP GPS Sync radio with Sectocal antenna First the new radio I connect with the sectoral antenna that is hit by lightning, the radio dies And then I test with another antenna that is dish, radio is on
