Radio Management VLAN is always 1?
The cnReach User Guide says "vlan 1 is always as the primary access to the radios".
We plan to use different VLANs and Subnets for radio management at different towers.
Is there a way to connect a trunk port with tagging (VLAN port tagging = All) to one of the Ethernet ports such that a vlan other than 1 is used for radio managment? This would be similar to changing the Management VID on PMP450.
What is the impact of setting a VLAN to be the Primary VLAN ID (PVID) on an interface? Is this related to management?
Don
And...
page 42 of the cnReach User Guide is garbled.
You should be able to create a different vlan (than vlan1) and assign an IP address to that vlan and use that IP address to access the radio.
