Radio Not calibrated
Hello !
I have been getting this error on many units, most of them re calibrated by Cambium support, but then i lose the llicence to 4mb agrregate and its hassle to get the proof to show them what speed they were purchased. Our network us running on the  firmware 14.1.1 and this keeps on happening, at time the unit de-registers totally.
Anybody else having same issues ? and how to solve this  so does not happen.
Hi Manish,
Since you are facing this on most of your radios, it will be great if you  can send us your query to support@cambiumnetworks.com.
We will definitely work on this and try to get you the resolution at earliest.
Thanks & Regards,
Yogesh Giriappa
Cambium Networks -Technical Support Team
We have the same problem on a radio, at the moment it is "In session" on the AP but it showing the error "Radio NOT Calibrated".
The license downgraded from 10 to 4.
******System Startup******
System Reset Exception -- User Initiated Reset
Software Version : CANOPY 14.1.1 SM-DES
Board Type : P11
Device Setting : 5.4/5.7GHz MIMO OFDM - Subscriber Module - 0a-00-3e-a0-4b-42
FPGA Version : 110815
FPGA Features : DES, Sched;
01/01/2011 : 00:01:15 UTC : :Time Set
03/31/2016 : 13:12:58 UTC : :Time Set
04/08/2016 : 16:35:43 UTC : :Error, bad input frequency: -2126525289
04/08/2016 : 16:36:12 UTC : :Error: Invalid frequency:6553600 for band:19
04/08/2016 : 16:36:19 UTC : :Error invalid frequency: -2126525289
04/08/2016 : 16:36:19 UTC : :Error: Calibration does not match frequency band:22, using first cal.
04/08/2016 : 16:36:19 UTC : Sector Spectrum Analysis complete for 10 seconds. Previously connected to AP: 0a-00-3e-b2-f7-3c;
04/12/2016 : 09:32:38 UTC : Sector Spectrum Analysis complete for 10 seconds. Previously connected to AP: 0a-00-3e-b2-f7-3c;
04/16/2016 : 18:17:22 UTC : :Unable to get encryption setting, Defaulting to Key!
01/01/2011 : 00:00:00 UTC : :
01/01/2011 : 00:00:00 UTC : :Time Set
System Reset Exception -- Power-On Reset
Board Type : P11
No valid accounts configured. Using default user account
Radio not calibrated
04/18/2016 : 21:18:21 UTC : :Time Set
Board Type : P11
04/18/2016 : 21:38:58 UTC : :Time Set
04/19/2016 : 01:54:00 UTC : :NI1: Unsupported packet type 0x24 from SrcMac B8:09:8A:17:18:19
Board Type : P11
04/19/2016 : 11:59:42 UTC : :Time Set
04/19/2016 : 12:42:33 UTC : :Web user; user=none; Reboot from Webpage;
04/19/2016 : 12:42:38 UTC : :Forced reset;
04/19/2016 : 12:42:39 UTC :
Board Type : P11
04/19/2016 : 12:46:06 UTC : :Web user; user=none; Reboot from Webpage;
04/19/2016 : 12:46:12 UTC : :Forced reset;
04/19/2016 : 12:46:13 UTC :
Board Type : P11
04/19/2016 : 12:50:25 UTC : :Flash Image Update OK
04/19/2016 : 12:50:42 UTC : :SNMP user; user=snmp; Reboot from SNMP;
04/19/2016 : 12:50:44 UTC : :SNMP user; user=snmp; Reboot from SNMP;
04/19/2016 : 12:50:44 UTC : :Forced reset;
04/19/2016 : 12:50:45 UTC :
Board Type : P11
