Will be great to re-design the plastic cover that snaps in to cover the connectors on the ePMP 1000 AP and other radios.
When you are on a top of a tower replacing or installing equipment and is windy, wet and conditions are terrible is almost impossible to take off or install the wires cover due the small size, lower round shape and flat slipery surface, besides almost everyone uses tough cables for the access points and the holes doesnt let you insert the cover all the way in.
The only solution is to add some duct tape on it after fighting to snap the cover in, and sometime the clip either doesnt clip or break.
Terrible design, I still dont understand how Cambium hasnt changed this part. Obiously the designer of this part of the radio cover hasnt climbed to the top of a tower yet.
Suggestion:
Two sizes options for the cable hole
Rugged or marked lines on the snap in cover
Better clip, perhaps on the sides
- epmp-cover.PNG (65.3 KB)
