I won’t bore you with the story, but after going crazy I discovered there’s a bug that can make your radios only sync with switch at 100Mbps rather than 1Gb.
This was caused by replacing the radio and using the backup feature, then uploading the config to a new radio. Yes I chose “do not support unsupported configuration elements” when I uploaded the backup file.
If you have a cambium radio that will not sync at 1Gb, and it got its config from a restore, try factory resetting it and manually building the config.
This is obviously a bug, but I cannot tell you what firmware as i’m not sure what the radio was running when I saved the buggy config file. I tried 4 radios and none of them would sync at 1Gb. Tried 2 switches and still no sync. Went mad then realised it might be the config file. Reset the radios then all 4 of them would sync at 1Gb.
This was a nasty bug that had me thinking first the cable was bad, then the switch was bad …
Good luck to you all. Speed your shiz up and beat Elon with better service
Can you advise what version you are using, as we have seen the same on some units (along with unreliable connections to the LAN side Cambium)
We are on 4.7
I recommend using the Raise Ticket option in the top right corner of this page and attaching the tech support files where the issue occurs.
Our engineer will assist you in isolating the problem!
RMA for one set of units already in progress via reseller (2 weeks with them and no ETA on replacement).
Same issue with second set, but 3rd set went into service without issues. Likely there will be RMA for the 2nd set too when my negineer gets a chance to raise it.
Andrii asks you to email him directly then he never replies. Has this three times so far. I guess its so it looks like its getting attention to forum users …
you can pull a config from the replacement radio while default, load your backup then do a compare in notepad++ and see which config is causing it, then remove it from the backup
