07/07/2015 : 12:08:55: :Error Initializing EAP Global Control Blocks, Error = -9202 07/07/2015 : 12:08:55: :AAA Functionality will not work until this problem is fixed
Device PMP100
Bord type:P9
Software version: 13.4
Did you download the new 13.4 Dictionary File? Are both the AP and the SMs on 13.4?
Is is error show when startup AP on version 13.1.2 I upgrade to 13.4 but error not clear. I not used dictionary file. It is error show only AP without trying connected SM On other ap after sometimes it is error after reboot cleared
@madmax123 wrote: Is is error show when startup AP on version 13.1.2 I upgrade to 13.4 but error not clear. I not used dictionary file. It is error show only AP without trying connected SM On otherap after sometimes it is error after reboot cleared
Please collect the CNUT Support Files for these radios, and contact Tier 1 support.
