Re: PTP450i and 4.9GHz ?
Hello,
Can you tell me what revision of Canopy software your radio is using currently?
4.9 should be available in Other/* regions on a RoW radio.  I tested locally and it appears to be working correctly.
Can you provide some detail and/or images that might explain the issue you're having?
Thanks.,
-Al
You're not seeing any frequencies in the list because 4.9 GHz uses a custom frequency list.  You must first configure the list of custom frequencies by following the steps shown below:
Once you've done that, go back to the Configuration-->Radio menu, and the dropdown should now contain the custom frequencies you added.  Be aware, only supported frequencies for your current channel bandwidth will appear in this list.
Hope that helps!
-Al
