Receive Tx power
Two epmp 300-25 PTP link.SM receive downlink RSSI is -50dBm but tx power on the SM is 3.Link capacity (uplink) is 15%.Any reasons
What is the RSSI on both sides of the link?
What wireless mode are you using for PtP?
On the AP/master side, do you see a setting for Subscriber Module Target Receive Level, and if yes, what is that set to?
The RSSI on the SM is -50dBm.
The wireless mode TDD
I think the subscriber module target receive level is set to -90
You want both your AP/master and SM/slave side to be the same RSSI around -50
That would mean that you need to set your AP/master’s Subscriber Module Target Receive Level to -50.
No,I want the TX power on the SM to increase from 3 upwards which I believe would increase the link capacity(uplink) percentage on the SM.
Problem solved.Thanks for your help
