Recommended Circuit Breaker Ampere Rating for PTP650/670
Hi All,
As mentioned in installation guide, “some installations will also require an additional circuit breaker or isolation switch to be fitted in the DC supply”, what is the recommended ampere rating for Circuit breakers that should be installed for AC/DC Enhanced power injectors and AC only power injectors ?
Hi All,
Any support here ?
