Remove T&C for all devices
Hello,
We are using Easypass for our guest wifi however the T&C popup is causing us some grief (iPhones in particular do not like redirection). Is there a way to remove this requirement completely? I’m thinking if I go to guest access and add a captive portal bypass user agent rule with a wildcard it will work but not sure.
Thank you
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
