We need to reset CPE100 back to default. On shelf radios have ip address and vlan set and cannot access them via ethernet. Unable to reconnect to original AP due to frequency change on AP. Is there a way to reset the CPE back to default settings so we can access?
Hi Arobo!
The 5G Fixed CPE can be booted to “Recovery” mode by doing a short power-on/power off/power on cycle, where the power off time is less than ~5secs.
At that point the CPE boots in Recovery and will respond to HTTP browsing on 169.254.1.1/16. This will bring up a webpage where you can rest the whole configuration to factory default. The CPE will then reboot the operational SW and be accessible on 169.254.1.1/16.
