I cannot get into the radio. I have tried the 10 second power 5 second no power option to get into recover mode… I can not log in
I have set my computer to 169.254.1.4 &. then to 169.254.1.2
I have tried to connect to the radio (169.254.1.1) in several different browsers… nothing
is there another way to reset the ptp650
Hi Mark
The PTP650 does not have a “reset” button like our PTP500/PTP600 radios
The recovery mode is entered by a short break of the power, as you describe
Procedure:
1 Apply power to PSU for at least 10 seconds.
2 Remove power for 5 seconds.
3 Re-apply power to the PSU.
4 When the unit is in recovery mode, access the web interface by entering the default IP address 169.254.1.1.
If you are still having problems then please contact our support team for assistance.
http://www.cambiumnetworks.com/support/contact-support
Regards
Julian
Hi Mark
I have had another look into this. In the latest revisions of teh user guide the duration of the “short power cycle” has been reduced to 2 seconds.
Please try removing the power for 2 seconds to enter recovery mode.
Regards
Julian
hi expert.
need to implent the link using PTP 250
already installing the equipments at bothh end points but i can not get the link.
need to know what thing to consider/ necessary for link establishment
I am facing similar issue. Did reset procedure as per cambium pre-defined procedures. But cannot access default IP or any IP. Plz help!
@Cambium_JulianK wrote:
Hi Mark
The PTP650 does not have a "reset" button like our PTP500/PTP600 radios
Procedure:
Regards
Julian
Which Cambium product are you using?
Thanks, Mark
