Mirko
(Mirko)
1
I've an ePMP1000 that I can access via SSH from a routerboard with 169.254.1.1
This devide has a particular configuration, and I want to reset it
What is command to reset via CLI to factory defualt configuration?
I can't find it on Knowledge
Regards
Fedor
(Fedor)
2
Hi Mirko,
You can use SNMP comand via CLI to reset ePMP board to factory default.
snmp set -v 2c -c private 127.0.0.1 .1.3.6.1.4.1.17713.21.4.2.0 i 1
Thank you.
Mirko
(Mirko)
3
The command give me this response
Timeout: No Response from 127.0.0.1
Mirko
(Mirko)
4
And sorry.. my private snmp has changed with another name that include "-" character.. but when I type it say Illegal pameter
Fedor
(Fedor)
5
Mirko,
Please try escaped community string value:
snmp set -v 2c -c "pri-vate" 127.0.0.1 .1.3.6.1.4.1.17713.21.4.2.0 i 1
Thank you.
hi is there an ssh command line that can be used? I tried that one but it doest not work
aka
(Andrii )
7
Hi @Jorge_Arriaga ,
here you go:
ePMP1000_c56453>config reset
A reboot is required for the changes to take effect.
ePMP1000_c56453>reboot
thank you Andrii appreciate
