Hi admin!
Last year, i used cnMaestro. The feature roaming history can use, but now i can't use it.
because i need show it for my customters, they need information.
Hi admin!
I can veryfy that, the roaming history is not display history right now.
we will look into this and update! What is the version of cnMaestro if we used on premises version!
i use this
That is version of firmware for APs, what version of cnMaestro are you using?
HI Mixig
Version 2.1.1-r37
I use over cloud.
We have found the root cause and issue will be fixed in the upcoming cnMaestro version - 2.2.0.
Ajay
The cnMaetro now is so slow, i hope we can use the new version as soon.
