The advantage of newer radios, such as the ePMP 4500 series, is their support for wider channel widths (80 MHz) and higher modulation rates (1024-QAM). However, achieving these higher modulation rates requires very high CINR, while wider channel widths increase the noise floor.
- 12X 4K-QAM (MCS 13) requires approximately 45 dB CINR
- 10X 1K-QAM (MCS 11) requires approximately 40 dB CINR
- 8X 256-QAM (MCS 9) requires approximately 30 dB CINR
- 6X 64-QAM (MCS 7) requires approximately 25 dB CINR
These are approximate design targets. Actual requirements depend on the radio and operating conditions.
Every time you double the channel width, you also double the amount of noise power, raising the noise floor by approximately 3 dB. Wider channels also increase the likelihood of encountering interference.
Similarly, every time you double the distance of a wireless link, free-space path loss increases by approximately 6 dB. For example, if you receive a signal of −66 dBm at 15 miles, you can expect approximately −72 dBm at 30 miles, assuming all other conditions remain the same.
The received signal level is determined by four primary factors:
- Remote-side transmit power
- Remote-side transmit antenna gain
- Free-space path loss
- Local-side receive antenna gain
You can calculate the expected received signal level using the link budget:
Received signal (dBm) = Transmit power (dBm) + Transmit antenna gain (dBi) − Free-space path loss (dB) + Receive antenna gain (dBi)
Once you know the expected received signal level and the local noise and interference levels, you can estimate the CINR and determine which modulation rates the link can reliably support.
With a -90 dBm noise floor, you can achieve 36 dB CINR to realize 1K-QAM modulation rates with the ePMP 4500L and Force 400c SM using the Cyber Antennas A20 horn and 1.8 m RP-SMA Dish. However, unless you plan on using high-gain antennas, either on the AP or client side, then you will not be able to benefit from the higher modulation rates available with the ePMP 4000 series.
The difference between Cyber Antennas and IsoHorns is that the advertised gain is the realized gain you can actually expect. Other antenna vendors use computer modeled gain values or best-case nominal gain values, which means the antennas often don’t perform as advertised.
