Can anyone tell me where to purchase an additional set of the 2 RP-SMA pigtails that come with the Cambium 90/120 Sector for the 2000AP or a replacement set that is similar with the rubber boots? It looks like the ones that come with the sector are about 8 inches long but they do have a loop when connected so they probably wouldn’t need to be that long.
Will the Ubiquiti IP67CA-RPSMA Cable work for it?
If the length is correct. Mikrotik has some longer ones that many distributors carry as well.
Thanks for the advice. The Ubiquiti cable is only about 4 inches but since the Cambium cable has a loop, I don’t think it needed to be that long. All of the cables I see that are made by Mikrotik don’t have the rubber boot unless I am overlooking it.
