Hello, I’ve a weir problem and any help will be appreciated.
I’ve one 5200AP (w/o reflector) and two 5200SM (with reflector) associated and registrated to the AP. The SM are located at one distance of 5Km .
Please look at the registration levels and details in the AP:
LUID: 002 : MAC: 0a-00-3e-00-4f-d9 State: IN SESSION (Encrypt Disabled)
Site Name : FOL
Software Version : CANOPY 7.0.7 Mar 02 2005 15:06:58
FPGA Version : 051104 (DES)
Session Timeout: 26, AirDelay 185
Session Count: 1, Reg Count 1, Re-Reg Count 0
RSSI (Avg/Last): 1591/1598 Jitter (Avg/Last): 2/2 Power Level (Avg/Last): -63/-62
DnRate: 3500 DnLimit: 10000 UpRate: 3500 UpLimit: 10000 (kbit)
LUID: 003 : MAC: 0a-00-3e-00-e4-1b State: IN SESSION (Encrypt Disabled)
Site Name : aeropuerto
Software Version : CANOPY4.2.1 Apr 16 2004 15:23:05
Software Boot Version : CANOPYBOOT 2.7
FPGA Version : 062403 (DES)
Session Timeout: 25, AirDelay 196
Session Count: 3, Reg Count 3, Re-Reg Count 0
RSSI (Avg/Last): 1229/1224 Jitter (Avg/Last): 4/4 Power Level (Avg/Last): -70/-70
DnRate: 10000 DnLimit: 10000 UpRate: 10000 UpLimit: 10000 (kbit)
The link test for the LUID02 :
Stats for LUID: 2 Test Duration: 8
Downlink RATE: 2488896 bps
Uplink RATE: 659008 bps
Downlink Efficiency: 63 Percent
Max Downlink Index: 96
Actual Downlink Index: 60
Expected Frag Count: 38889
Actual Frag Count: 64754
Uplink Efficiency: 93 Percent
Expected Frag Count: 10297
Actual Frag Count: 11028
The link test for the LUID03 :
Stats for LUID: 3 Test Duration: 8
Downlink RATE: 1667520 bps
Uplink RATE: 615808 bps
Downlink Efficiency: 58 Percent
Actual Downlink Index: 56
Expected Frag Count: 26055
Actual Frag Count: 45989
Uplink Efficiency: 92 Percent
Expected Frag Count: 9622
Actual Frag Count: 10370
The ping to the LUID02 and LUID03 :
64 bytes from 201.93.223.169: icmp_seq=88 ttl=63 time=233 ms
64 bytes from 201.93.223.169: icmp_seq=89 ttl=63 time=658 ms
64 bytes from 201.93.223.169: icmp_seq=90 ttl=63 time=53.7 ms
64 bytes from 201.93.223.169: icmp_seq=91 ttl=63 time=93.3 ms
64 bytes from 201.93.223.169: icmp_seq=92 ttl=63 time=25.7 ms
64 bytes from 201.93.223.169: icmp_seq=93 ttl=63 time=151 ms
64 bytes from 201.93.223.169: icmp_seq=94 ttl=63 time=23.6 ms
64 bytes from 201.93.223.169: icmp_seq=95 ttl=63 time=115 ms
64 bytes from 201.93.223.169: icmp_seq=96 ttl=63 time=55.5 ms
64 bytes from 201.93.223.169: icmp_seq=97 ttl=63 time=125 ms
64 bytes from 201.93.223.169: icmp_seq=98 ttl=63 time=461 ms
64 bytes from 201.93.223.169: icmp_seq=99 ttl=63 time=483 ms
64 bytes from 201.93.223.169: icmp_seq=100 ttl=63 time=120 ms
— 201.93.223.169 ping statistics —
100 packets transmitted, 99 received, 1% packet loss, time 99154ms
rtt min/avg/max/mdev = 23.634/267.457/1174.612/251.094 ms, pipe 2
As you can see, the latency is very terrible !! and the data transfer from adn to remote are very slow.
What can I do to fix this problem ?
