Scale parameter Xirrus
Good afternoon,
What´s the meaning of the parameter Scale in Xirrus Cloud design tool? . If you type a short value it the signal propagates for longer distances and it´s true for the opposite: The longer the value , propagations of signal is shorter.
Could someone explain it?
In the tool, the Scale is for designating the scale of the floor plan. As an example, a line of one inch in the floor plan equals 10 feet in the actual environment. Hope that helps.
Hi, thanks for the answer. But it does not influence the coverage, right?
By changing the Scale value to accurately size a section of wall to match the actual distance will provide a accurate representation of the coverage that is experiance.
I.e. Like Gary said if a measured wall is 10 ft but the real scale is 2 ft then the coverage would be displayed that is not accurate.
