How can I tell difference between a 90deg and 120deg sector antenna when it’s already mounted on a tower? I don’t see any part numbers readily visible. Do have to take it off air and the radio off to see a part #? Thanks
Cambium part number Antenna Type Gain (dBi)
C050900D003A 5 GHz Sector Antenna 90 degree 15
C050900D002A 5 GHz Sector Antenna 120 degree 15
C024900D004A 2.4 GHz Sector Antenna 90 /120 degree 15
Yes, you have to take it off air to see a part #
If you got rid of the box you can not find the part #, the only thing on the antenna is a serial number.
