I have a customer that would like to disable all internet for specific times of the day. I see how this can be done for wifi, but we need to be able to block lan ports as well during these time frames. Is this possible? if so, how do we accomplish this task? Thanks
Jon
Hi Jonathon,
I believe you have already gone through the KB writeup on wifi scheduling. There is no support for sechudling internet access on LAN ports in cnPilot R200/201 devices.
However if the customer is using PPPoE for uplink, then they can schedule the PPPoE connection, to achieve the same.
Ashutosh
