- On PRTG Network Monitor, add an ePMP radio under the Devices tab. Please make sure to add it under the correct group with the correct SNMP read/write string. You can test newly added ePMP device by creating a Ping Sensor.
- On Paessler MIB Importer (for example V3.4.8 alpha), chose Import MIB File under the File menu. Browse and select the ePMP MIB file downloaded from ePMP website for 1.3.4 version.
- Once the MIB file populates with all OIDs, chose Save for PRTG Network Monitor under the File menu and chose a name (e.g “ePMP” ) and save under the default snmplibs directory of PRTG.
- Back on the PRTG Network Monitor, right-click on the previously added ePMP radio and choose Add Sensor.
- Next on the Add Sensors screen, please click on SNMP under the “Technology Used” section. This will give you SNMP options at the bottom. Please click on SNMP Library. From a pop-up menu, please chose the library file saved earlier (e.g. ePMP.oidlib ) and press Ok.
- Now, back to Sensor Settings is where you can choose all or required OIDs/statistics then press Continue.
- It may take a few seconds to populate current values of selected OIDs depending upon the connection to the Device.
