Hello,
I have 2 CnMatrix switches (EX2082-P and EX2052-P) that I want to connect to 10G via an SFÜP+ module. I have the following module:
F24-CI-SFP-10G-SR
With these modules, an LED flashes orange on both switches. On the switch that is connected to the Internet, the blue LED for the CNMaestro connection goes out after a short time and only flashes. I no longer have access to this switch. If I pull the modules off again, then it works again.
Please check with other vendor SFP+ transciever
Sometimes in Cambium I had trouble with some types of the SFP/SFP+ transcievers.
In some cases I use only oryginal.
