SIP Dial Rules R201P
Hi there,
I’m having a hard time wrapping my head around the dial rules on this thing. Is it possible to add the local area code do a dialed out number if they only enter xxxxxxx?
1555xxxxxxx for example?
Also add the leading 1 if that’s omitted?
Thanks!
If nothing else, is there some kind of protocol this follows I can research? It doesn’t seem to match cisco or Asterisk methods, so I’m scratching my head on how to make it work. I’ve tried to glean as much as I could from the product manual, but without some real world examples I’m stuck.
Well, it’s been a while, but to answer my own question I found it uses the same protocol as Linksys ATAs, and the format for this would be <:1555>xxxxxxx
https://wiki.voip.ms/article/Dial_Plan_for_Linksys_ATAs
Hopefully this helps somebody in the future.
