Slow wifi speeds cnPilot R190W
We had a customer call in complaining about slow wifi speeds, so we went and ran a test.  We tested plugged into the NID outside and got the correct speed (about 50mbps).  We came in and plugged into the router and ran it, and got about 50mbps again.  Then we ran it on wifi and it would start the test anywhere from 35-43mbps and then slowly decrease to about 22-25mbps which is where it would finish.  We restarted his router and ran the test again with the same results.  We brought a new router and tried the same thing with the same results.  We took the router back to our office and hooked it up to our 100mbps port and ran the same tests.  Plugged into the LAN we would get about 97-98mbps, but wirelessly we were starting out around 75, then finishing the test at about 50mbps.  I'm not sure what else to try.  Is it possible we just tried two bad routers?  Is this common?
Both routers we used were cnPilot R190W's running version 4.4.2-R2.
Can you share your configuration please. What is the channel setting, if it is manual, can you try a different channel. Also what is the channel bandwidth configuration ?
ashutosh
DBID_DBASE_VERSION=1
DBID_CFWD_NOANS_OFF_CODE=
HT_AutoBA=1
DBID_RINGTONE4_T=
DBID_RRTP=0
DBID_SIP_ANONYMOUS=0	0	0	0	0	0	0	0
mwan_dhcpEnd=192.168.11.254
DBID_SIP_MIN_RANDOM_PORT=50000	50000	50000	50000	50000	50000	50000	50000
DBID_PRV_RANDOMSEED=1
ipsec_conn_name=
way_access_web=http&https
DBID_MP_INACTIVE_TIME=0	0	0	0	0	0	0	0
DBID_SIP_REMOVE_ALL_BINDING_ENABLE=0	0	0	0	0	0	0	0
Key1Type=0
SyslogLevel=INFO
DBID_HOOK_FLASH_MIN=0.1	0.1	0.1	0.1	0.1	0.1	0.1	0.1
DBID_RANDOM_DELAY=40
DBID_SIP_HOSTPORT_ENABLE=0	0	0	0	0	0	0	0
DBID_SAC_DND_DEACT_VALUE=*79	*79	*79	*79	*79	*79	*79	*79
DBID_DST_TIME_SHIFT=60
WanIngressRate=100000
ipsec_right_type=subnet
DBID_SIP_RECEIVED_DETECTION=0	0	0	0	0	0	0	0
WscAKMP=1
DBID_PRV_DRL_ENABLE=1
IPPortFilterRules=
DBID_UPGRADE_FTP_PWD=user
mwanConnectionMode=DHCP
DBID_FIXED_IP_ADDR=0.0.0.0
BasicUser=useradmin
WanEgressRate=100000
DBID_TRANSFER_DISABLE=
DBID_VPN_USER=
DBID_MEGACO_MGIP=
DBID_SIP_TRANSPORT=0
DBID_FAX_BYPASS_ATTRIBUTE_VALUE=0	0	0	0	0	0	0	0
DBID_REGIONAL_DIAL_T=350@-19,440@-19;30(*/0/1+2)	350@-19,440@-19;30(*/0/1+2)	350@-19,440@-19;30(*/0/1+2)	350@-19,440@-19;30(*/0/1+2)	350@-19,440@-19;30(*/0/1+2)	350@-19,440@-19;30(*/0/1+2)	350@-19,440@-19;30(*/0/1+2)	350@-19,440@-19;30(*/0/1+2)
RADIUS_Key1=ralink
lan_ipaddr_v6=FD00::1
DBID_PRACK_ENABLE=0	0	0	0	0	0	0	0
vendor4syslog=CAMBIUM NETWORKS
WdsList=
DBID_ANONYMOUS_CALL_BLOCK=0	0	0	0	0	0	0	0
DDNS=
DBID_MIC_BOOST=0	0
DBID_PRIMARYSER_DETECT_INTERVAL=0	0	0	0	0	0	0	0
lan_default_dhcpEnd=192.168.11.254
PortForwardEnable=0
DBID_ENABLE_FEATURE_NUMBER=0	0	0	0	0	0	0	0
DBID_DTMF_RTPEVENT_END_COUNT=10
DBID_MEGACO_RTP_PORT_END=
DBID_MEGACO_MACADDR_AS_MGNAME_ENABLE=
DBID_TR_SSL_VERSION=TLSv1
DBID_PSTNSWITCH_ENABLE=0
DBID_SAC_CW_ACT_ENABLE=1	1	1	1	1	1	1	1
DBID_VPN_PWD=
DBID_ALARM_TIME_INPUT=00:00
RADIUS_Port=1812
DBID_R_TRANSFER_KEY_CODE=R4	R4	R4	R4	R4	R4	R4	R4
DBID_SIP_PORT_GROUP_PASSWORD=
APCwmin=4;4;3;2
DBID_SIP_SMS_SERVER_DOMAIN=
DBID_VPN_INITSRV_IP=
DBID_CTCOM_SAVE_MANAGE_PWD=
DBID_CFWD_NO_ANS_ENABLE=0	0	0	0	0	0	0	0
DBID_TR_PERIODIC_INFORM_INTERVAL=30
WscUseUFD=0
DBID_SAC_CID_ACT_VALUE=*65	*65	*65	*65	*65	*65	*65	*65
DBID_FEATURECODE_CALL_ACT=*124	*124	*124	*124	*124	*124	*124	*124
wlan_vid=
DBID_SAC_SPD_ACT_ENABLE=1	1	1	1	1	1	1	1
DBID_PCMU_WB_PAYLOAD=110
DBID_RTP_STATISTICS_SERVER_URL=https://analytics.nettalkconnect.com:1891/api/v1/callquality
RTDEV_CountryRegionABand=10
DBID_MEGACO_BACKUP_MGC_PORT=2944
DBID_INNERNUMBER=
DBID_PRV_PBK_ENABLE=1
DBID_SIP_PORT_GROUP_ACCOUNT=
dhcpDnsMode=Manual
DBID_HTTP_URL=http://softphone.capcom.net/calling.php
DBID_ALARM_REPEAT_THURSDAY_EN=0
PrvClientCertFile=/etc/provision/ssl_client_cert
RemoteSyslogEnable=0
DBID_STUN_ENABLE=0
DBID_SIP_SMS_OUTBOUND_DOMAIN=
DBID_SIP_P_ACCESS_NETWORK_INFO_ENABLE=0	0	0	0	0	0	0	0
DBID_FIRST_USE_DEVICE=1
DBID_BITTEL_VMWI_TRANS_TIMES=0
mwan_pppoe_opmode=KeepAlive
DBID_SIP_REG_LONG_RETRY_INTERVAL=1200	1200	1200 1200	1200	1200	1200 1200
MacFilterRules=
DBID_IPMODE=DHCP
DBID_MP_ACTIVE_TIME=2000	2000	2000	2000	2000	2000	2000	2000
DBID_CONGESTONE_RESPCODE=503
DBID_TRAN_NO_ANSWER_DELAY=20	20	20	20	20	20	20	20
DBID_SIP_CALLBACK_ENABLE=1	1	1	1	1	1	1	1
PrvCACertFile=/etc/provision/ssl_ca_cert
DeviceManagementSyslogEnable=1
lan3_bind_wan_id=1
DBID_SIP_SMS_OUTBOUND_ADDRESS=
DBID_FEATURE_NUMBER=**	**	**	**	**
AccessControlList0=
AccessControlList1=
AccessControlList2=
DBID_SIP_DOMAIN_NAME=
BSSCwmin=4;4;3;2
AccessControlList3=
Tr069ConfChecksum=7788520
Lan1IngressRate=100000
DBID_LCD_BACKLIGHT_TIMER=0
DBID_REGIONAL_HOLDING_T=600@-19;25(.1/.1/1,.1/.1/1,.1/9.5/1)	600@-19;25(.1/.1/1,.1/.1/1,.1/9.5/1)	600@-19;25(.1/.1/1,.1/.1/1,.1/9.5/1)	600@-19;25(.1/.1/1,.1/.1/1,.1/9.5/1)	600@-19;25(.1/.1/1,.1/.1/1,.1/9.5/1)	600@-19;25(.1/.1/1,.1/.1/1,.1/9.5/1)	600@-19;25(.1/.1/1,.1/.1/1,.1/9.5/1)	600@-19;25(.1/.1/1,.1/.1/1,.1/9.5/1)
DBID_CONFERENCE_METHOD=0	0	0	0	0	0	0	0
DBID_MAX_JITTER_TIME=160	160	160	160	160	160	160	160
rtp_vid=2
DBID_MEGACO_PHYNAME_PREFIX=C0
DBID_ALARM_REPEAT_WEDNESDAY_EN=0
DMZAddress=
mdhcpVendor=Cambium-cnPilot R190W
DBID_SIP_CALLQUEUED_ENABLE=0	0	0	0	0	0	0	0
DBID_SIP_OUTBOUND_DOMAIN=
EncrypType=AES
DBID_ALTER_SIP_SERVER_PORT=5060	5060	5060	5060	5060	5060	5060	5060
RTDEV_SSID1=CAMBIUM_5GHz_03C120
DBID_STATUS_TRAP_PERIOD=600
DBID_PRV_DRL_RULE=
HSCounter=0
DBID_PPPOE_MRU=1500
HostName=cnPilot-R190W
DBID_PRODUCT_DESCIRBE=IPPhone
DBID_SIP_SUBSCRIBE_EXPIRES=
DeviceAlarmSyslogEnable=1
DBID_SIP_SMS_DOMAIN=
cns_static_url=66.43.253.28
DBID_NAT_LEASE_TIME=15	15	15	15	15	15	15	15
gkSnmpDoubleServerPort=
radvd_advertise_interval=30
DBID_DMZ_END_PORT=2024
DBID_WEB_SIP_OUTBOUND_PORT=5060	5060	5060	5060	5060	5060	5060	5060
DBID_SIP_IMS_P_HEADER_STRICT_CHECK=0	0	0	0	0	0	0	0
DBID_SIP_AUTO_REDIAL_DEACT=*86	*86	*86	*86	*86	*86	*86	*86
DBID_STUN_FRESH_TIME=60
DBID_SIP_PORT_GROUP_OUTBOUND_PORT=5060	5060	5060	5060	5060	5060	5060	5060
DBID_SIP_CALLWAITING_ENABLE=1	1	1	1	1	1	1	1
management_use_vpn=0
DBID_SIP_REG_AND_CALL_SHARE_CONNECTION=1
DBID_MEGACO_HEARTBEAT_ENABLE=
DBID_SYSLOG_LEVEL=3
DBID_ALTER_SIP_SMS_SERVER_PORT=5060	5060	5060	5060	5060	5060	5060	5060
DBID_SETVOLUMN_BELL=5
DBID_STUN_SERVER_IP=
DBID_MAX_FORWARD=70
DBID_SIP_CALLER_PREFERENCE=
DBID_G723_BITRATE=0	0	0	0	0	0	0	0
DBID_UPGRADE_RULE=
DBID_VOREPORT_DIPLAY_NAME_CODE=#00	#00	#00	#00	#00	#00	#00	#00
DBID_SUBNET_MASK=255.255.255.0
DBID_RINGTONE=0
DBID_SAC_CW_DEACT_VALUE=*71	*71	*71	*71	*71	*71	*71	*71
DBID_DELAY_THRESHOLD=150
DBID_SAC_CW_ACT_VALUE=*70	*70	*70	*70	*70	*70	*70	*70
HT_MCS=33
DBID_ESCAPED_CHAR_ENABLE=0	0	0	0	0	0	0	0
DBID_SAC_CFWD_NOANS_DEACT_ENABLE=1	1	1	1	1	1	1	1
DBID_SIP_CALLINFO_ENABLE=0	0	0	0	0	0	0	0
DBID_DISPLAYNAME_COLOR=5
ipsec_protocol=
DBID_RING3_CALLER=
lan_default_dhcpStart=192.168.11.2
DBID_SIP_DTMF_MODE=1	1	1	1	1	1	1	1
Lan3EgressRate=100000
ipsec_type=gateway
DBID_T38_ENABLE=1	1	1	1	1	1	1	1
DBID_SIP_ALTER_DIS_NAME=
DBID_SIP_RANDOM_PORT_ENABLE=0	0	0	0	0	0	0	0
DBID_MEGACO_RTP_PORT_START=
DBID_RFC2543_CALLHOLD=1
wipo_enable=0
Platform=MT7628
dhcpPriDns=192.168.11.1
DBID_TRAN_DELAY=0	0	0	0	0	0	0	0
DBID_IDLE_POLARITY=0
dev_name=
HT_OpMode=0
MostNatConnections=4096
lan_wan_physical_br=0
DBID_PRV_GPP_SA=
DBID_PRV_GPP_SB=
DBID_BK_ROOT_ZONE=1
DBID_INTER_PORT_CALL_KEY_CODE=***7	***7	***7	***7	***7	***7	***7	***7
DBID_PRV_GPP_SC=
DBID_FAX_GPMD_ENABLE=0	0	0	0	0	0	0	0
DBID_R_HOLD_KEY_CODE=R2	R2	R2	R2	R2	R2	R2	R2
DBID_PRV_GPP_SD=
PRV_COMMAND_FILE=
DBID_CLONE_MAC_ADDRESS=
DBID_SAC_CFWD_BUSY_DEACT_VALUE=*91	*91	*91	*91	*91	*91	*91	*91
DBID_SIP_ANONYMOUS_CODE_DEACT=*68	*68	*68	*68	*68	*68	*68	*68
SSH_SERVER_LOCAL_ENABLE=1
DBID_MAC_ADDRESS=
HT_RDG=1
DBID_DND_ON_CODE=
DBID_RINGTONE5_T=
DBID_SW_VERSION=316
mdns_mode=0
SwVlan1=enable,1,untag,unset,unset,unset,unset
CountryRegion=0
E2pAccessMode=2
SwVlan2=enable,2,unset,untag,untag,untag,untag
wan_pptp_mode=0
SnmpKeepAlivePeriod=300
session_timeout_interval=0
DBID_VPN_VIRTUAL_IP=0.0.0.0
DBID_PCMA_WB_PAYLOAD=111
wan_l2tp_user=
DBID_CODEC_LOOP_CURRENT=26	26	26	26	26	26	26	26
DBID_SAC_CFWD_ALL_ACT_ENABLE=1	1	1	1	1	1	1	1
Key4Type=0
DBID_INVOICE_GAIN_WITH_DB=-6	-6	-6	-6	-6	-6	-6
DBID_PPPOE_MTU=1500
lltdEnabled=0
DBID_MAX_AUTHEN=2
ipsec_nat_trans_en=enable
wireless_wan_ipaddr=192.168.0.168
DBID_OPUS_PAYLOAD=114
mwan_is_bridge=Route
DBID_GMANAGER_MODE=0
DBID_BT_PROMPT_ENABLE=0
DBID_DST_END_BY_WEEK=10.5.0.2
DefaultKeyID=2
DBID_SIP_COMPLETE_REG=0	0	0	0	0	0	0	0
dnsPEnabled=1
DBID_DMZ_IP=
DBID_TR069_DEBUG_ON=0
DBID_LTE_SIM_CODE=*81*	*81*
serverRFlowPort=2055
ipsec_left_id=
DBID_DST_START_BY_WEEK=04.1.0.2
RADIUS_Acct_Port=1813
DBID_AMR_NB_PAYLOAD=98
wan_pppoe_pass=
DBID_VOREPORT_LOCAL_IP_CODE=#*111	#*111	#*111	#*111	#*111	#*111	#*111	#*111
DBID_SAC_DND_DEACT_ENABLE=1	1	1	1	1	1	1	1
DBID_TR_ACS_URL=
RemoteTelnet=0
DBID_QOS_TOS=0
DBID_DATA_TOS=0
DBID_LCD_BRIGHTNESS=15
DBID_RING_VOL=5	5
DBID_UPDATE_TYPE=0
DBID_REGIONAL_CALLWAITING_T=440@-19;*(.3/10/1)	440@-19;*(.3/10/1)	440@-19;*(.3/10/1)	440@-19;*(.3/10/1)	440@-19;*(.3/10/1)	440@-19;*(.3/10/1)	440@-19;*(.3/10/1)	440@-19;*(.3/10/1)
DBID_SAC_CONF_CODE_VALUE=*88	*88	*88	*88	*88	*88	*88	*88
DBID_SIP_REG_RETRY_RESPCODE=
DBID_DOWNGRADE_LIMIT=0
BasicRate=15
Lan2EgressRate=100000
DBID_SIP_ENABLE=0	0
DBID_LAN_LOGIN_ONLY=1
DBID_RING2_CALLER=
DBID_FEATURECODE_CALL_BLOCK=*123	*123	*123	*123	*123	*123	*123	*123
DBID_ALERT_CFWD_T=425@-19;5(.25/.15/1)	425@-19;5(.25/.15/1)	425@-19;5(.25/.15/1)	425@-19;5(.25/.15/1)	425@-19;5(.25/.15/1)	425@-19;5(.25/.15/1)	425@-19;5(.25/.15/1)	425@-19;5(.25/.15/1)
DBID_TR_SSLKEY=
wan_pptp_ip=
WdsEncrypType=NONE
DBID_ALARM_REPEAT=0
mwan_tag_mode=0
DBID_OUTVOICE_NUM=5	5	5	5	5	5	5	5
PortForwardRules=
APTxop=0;0;94;47
WscActionIndex=9
DBID_R_KEY_ENABLE=0	0	0	0	0	0	0	0
wanmode_v6=DHCPv6
DBID_TIME_ZONE=4
DBID_RTP_PORT=0	0	0	0	0	0	0	0
DBID_METERING_FREQ=0	0	0	0	0	0	0	0
dns_mode=0
DBID_WARNING_DELAY=4
wireless_access_web=0
WscPinCode=
WscConfStatus=2
DBID_MEGACO_ENABLE=0
SNMPErrorCommunity=error
IpphoneSyslogEnable=1
DBID_LOCAL_IP=192.168.11.1
DBID_TRAN_BUSY_NUMBER=
wan_secondary_dns=
DBID_SAVE_LOG_TO_FLASH=1
DBID_REMOTE_DSP_SERVICE_EN=0
DBID_SIP_OUTBOUND_PORT=5060	5060	5060	5060	5060	5060	5060	5060
DisableOLBC=0
DBID_WEB_SIP_OUTBOUND=
DBID_SETVOLUMN_MESSAGE=2
DBID_MEGACO_HEARTBEAT_CYCLE=
PreAuth=0
AuthMode=WPA2PSK
SNMPKeepAlivePort=162
DBID_SIP_AUDIO_TYPE10=9	9	9	9	9	9	9	9
DBID_SIP_PORT_GROUP_MEMBER=
wan_netmask=
DBID_SIP_AUDIO_TYPE11=10	10	10	10	10	10	10	10
mwan_nat_en=1
DBID_SIP_AUDIO_TYPE12=11	11	11	11	11	11	11	11
DBID_DNSSRV_DOMAIN=
DBID_WIRELESS_REGION=1
DBID_SAC_DND_ACT_VALUE=*78	*78	*78	*78	*78	*78	*78	*78
DBID_MEGACO_PRIMARY_MGC=125.152.96.5
NTPServerIP=pool.ntp.org
DBID_SIGNAL_ENCRYPT=0	0	0	0	0	0	0	0
HT_LinkAdapt=0
mwan_secondary_dns=
DBID_BITTEL_VMWI_FLAG=0
DBID_REG_RETRY_DELAY_TIMER_TYPE=0
DBID_AMR_WB_PAYLOAD=100
Lan4IngressRate=100000
PrvClientKeyFile=/etc/provision/ssl_client_key
DBID_ARP_SP_ENABLE=1
gkSnmpDeviceIdentifier=
DBID_CUSTOM_LCD_LOGO=
gkSnmpServer=
mwan_1p=0
DBID_WEB_SIP_SERVER_PORT=5060	5060	5060	5060	5060	5060	5060	5060
DBID_MEGACO_BACKUP_MGC=
DBID_CALL_DISPLAY=0
DBID_SAC_CFWD_NOANS_ACT_ENABLE=1	1	1	1	1	1	1	1
mwan_dhcpStart=192.168.11.2
OperationMode=1
WscRegResult=1
DBID_SIP_PHONE_NUM=
DBID_CFWD_ALL_ENABLE=0	0	0	0	0	0	0	0
wlan4_bind_wan_id=1
DBID_REGIONAL_CALLER_ID_METHOD=0	0	0	0	0	0	0	0	0
RekeyMethod=TIME
DBID_PPPOE_ACCOUNT=
DBID_REGIONAL_RING_TYPE=60(2/4)	60(.5/.1,.5/2)
DBID_AUTO_HOOKON_NODELAY=0	0	0	0	0	0	0	0
DBID_RING1_CALLER=
DBID_SIP_REG_SUBSCRIBE_INTERVAL=0	0	0	0	0	0	0	0
lan4_bind_wan_id=1
DBID_TR_STUN2ACS=1
mwan_pppoe_idle_optime=5
DBID_CODEC_OPEN_VOLTAGE=48	48	48	48	48	48	48	48
DBID_R_REJECT_KEY_CODE=R0	R0	R0	R0	R0	R0	R0	R0
WscUseUPnP=1
DBID_BK_IMG_AVAILABLE=0
DBID_SIP_KEEPALIVE_USER_NAME=
TurboRate=0
NoForwarding=0
VLANID=0
DBID_SIP_SMS_OUTBOUND_PORT=5060	5060	5060	5060	5060	5060	5060	5060
SecondNTPServerIP=
mwan_lan_isolation=0	0	0	0	0
DBID_SIP_ACCOUNT=
DBID_CONTACT_LOCAL_IP_ENABLE=1
DBID_AUTOANSWER_SPECIFY_PHONENUM=
DBID_SIP_AUDIO_TYPE1=1	1	1	1	1	1	1	1
DBID_SIP_AUDIO_TYPE2=0	0	0	0	0	0	0	0
DBID_SIP_T1_TIME=500
lte_4Gconnect_type=0
DBID_SYSLOG_SERVER=
DBID_SIP_AUDIO_TYPE3=3	3	3	3	3	3	3	3
TZ=CST_-06
DBID_SIP_AUDIO_TYPE4=2	2	2	2	2	2	2	2
cns_manage_mode=0
BSSTxop=0;0;94;47
DBID_NAT_ENABLE=1	0	0	0	0	0	0	0
DBID_AUTO_GAIN_CONTROL=0	0	0	0	0
DBID_SIP_AUDIO_TYPE5=4	4	4	4	4	4	4	4
DBID_SIP_AUDIO_TYPE6=5	5	5	5	5	5	5	5
DBID_SIDE_TONE_VOL=5	5	5	5	5	5	5	5
DBID_IMPEDANCE_MATCHING=0	0	0	0	0	0	0	0
DBID_SIP_AUDIO_TYPE7=6	6	6	6	6	6	6	6
WscConfigMethod=138
DBID_SIP_AUDIO_TYPE8=7	7	7	7	7	7	7	7
DBID_SAC_CFWD_NOANS_DEACT_VALUE=*53	*53	*53	*53	*53	*53	*53	*53
BsLan3Rate=255
DBID_SIP_PORT_CHANGE_REG_FAILED_TIMES=3
DBID_SIP_AUDIO_TYPE9=8	8	8	8	8	8	8	8
APSDCapable=0
DBID_PRV_ACCOUNT_NUMBER=
DBID_SIP_ALLOWED_IP_ADDRS=
DBID_SPEED_DIAL10=
DBID_SPEED_DIAL11=
DBID_SIP_ALTER_PASSWORD=
DBID_SPEED_DIAL12=
DBID_CFWD_BUSY_ON_CODE=
DBID_SPEED_DIAL13=
DBID_SPEED_DIAL14=
PrvClientKeyPass=wharever
DBID_SPEED_DIAL15=
DBID_DISPLAYNAME_INPUT=
DBID_USE_DMZ=0
DBID_DTMF_UPEVENT_ENABLE=0	0	0	0	0	0	0	0
telnet_vid=2
DBID_ALTER_VPN_VIRTUAL_IP=0.0.0.0
DBID_TLS_PRIVATE_PASS=
DBID_ONLY_SEND_UNREG_BEFORE_REBOOT=0	0	0	0	0	0	0	0
SSH_SERVER_REMOTE_ENABLE=0
WebIdleTimeout=5
wireless_dns_mode=0
websFilterEnable=0
mwan_gateway=
DBID_WMI_PHONE=
DBID_UPLOAD_RTPSTATISICS_ENABLE=0
lan_ipaddr=192.168.11.1
rateLimitEnable=0
DBID_RINGTONE1_T=
DBID_TRAN_UN_ALL_NUMBER=
DBID_ALARM_REPEAT_COUNT=1
mwan_netmask=
DBID_SIP_ALTER_PHONE_NUM=
serverRFlowInterval=15
DBID_SAC_CID_DEACT_ENABLE=1	1	1	1	1	1	1	1
DBID_RINGTONE6_T=
lte_enable=0
AntiDos=Enable
SNMPTrapServerAddress=
ipsec_right=
DDNSAccount=
RadioUseVPN=0	0	0	0	0	0	0	0
DBID_RING8_CALLER=
cns_dhcp_15_domain=
wan_gateway=
WdsEnable=0
mwan_dhcp_fwd_type=0
DBID_SAC_CW_DEACT_ENABLE=1	1	1	1	1	1	1	1
Key2Type=0
DBID_HOTLINE_NUMBER=
DBID_IVR_KEY_CODE=****	****	****	****	****	****	****	****
DBID_INVOICE_NUM=5	5	5	5	5	5	5	5
prior_link=wired
DBID_LCD_LANGUAGE=0
DBID_UPGRADE_FTP_USER=user
DBID_TR_FIRST_INSTALL=0
HT_MIMOPS=3
DBID_DSP_VERSION=
DBID_TR_ACS_PWD=WFVC05DSKTHS
ipsec_right_subnet=
DBID_SIP_HIDE_CALLERID=0	0	0	0	0	0	0	0
DBID_SIP_ANONYMOUS_SINGLE_CODE_ACT=*81	*81	*81	*81	*81	*81	*81	*81
ipsec_auth_type=
HT_40MHZ_INTOLERANT=0
DBID_ET_ENCRYPT_TYPE=0	0	0	0	0	0	0	0
DBID_CALLER_POLARITY=0
DBID_ALARM_REPEAT_SATURDAY_EN=0
DBID_REGIONAL_CPC_DELAY=0	0	0	0	0	0	0	0
DBID_LOOP_TEST_EN=0
DBID_BLFLIST_URI=
arpFirewallEnable=0
DBID_NB_PHONES_IN_USE=5
DBID_REGIONAL_OFF_HOOK_T=480@-19,620@-19;*(.25/.25/1+2)	480@-19,620@-19;*(.25/.25/1+2)	480@-19,620@-19;*(.25/.25/1+2)	480@-19,620@-19;*(.25/.25/1+2)	480@-19,620@-19;*(.25/.25/1+2)	480@-19,620@-19;*(.25/.25/1+2)	480@-19,620@-19;*(.25/.25/1+2)	480@-19,620@-19;*(.25/.25/1+2)
wan_l2tp_mode=0
WscConfigured=1
PARAM_VERSION=1.0.0
wan_l2tp_netmask=
DBID_SAC_CONF_CODE_ENABLE=1	1	1	1	1	1	1	1
DBID_ALARM_REPEAT_TUESDAY_EN=0
Lan1EgressRate=100000
DBID_CTCOM_AUTO_LOGIN=
lan_webport=80
PrvUserPass=WFVC05DSKTHS
DBID_FAX_BYPASS_ENABLE=0	0	0	0	0	0	0	0
DBID_SIP_CALL_ID_WITH_HOST=0	0	0	0	0	0	0	0
KernelSyslogEnable=1
DBID_UPGRADE_ENABLED=1
DBID_SAC_BLIND_TRANSFER_CODE_ENABLE=1	1	1	1	1	1	1	1
DBID_HOLD_METHOD=0	0	0	0	0	0	0	0
DBID_CONFRENCE_DISABLE=
DBID_SIP_DIALMODE=0
HT_LDPC=0
DDNSPassword=
DBID_DETECT_MAX_FAILCOUNT=3	3	3	3	3	3	3	3
cns_dhcp_81_url=
staWirelessMode=9
mwan_id=1
wireless_wanConnectionMode=DHCP
DBID_PRIVATE_IP_SECOND_SERVER_USED=0	0	0	0	0	0	0	0
NTPSync=60
DBID_SIP_PORT_GROUP_PROXY_PORT=5060	5060	5060	5060	5060	5060	5060	5060
DBID_LOCAL_MASK=255.255.255.0
VLANPriority=0
DBID_HF_OUT_VOL=5	5
DBID_REGIONAL_RING_FREQUENCY=20	20
wlan1_bind_wan_id=1
radvd_managed_flag=0
BssidNum=1
cns_cloud_en=1
DBID_ALARM_ENABLED=0
DBID_RESYNC_AFTER_UPGRADE=1
DBID_SIP_OUTBOUND_ADDRESS=
DBID_HOOK_DISABLE=0
DBID_Q931_PORT=9080
SSID1=Barlow_2.4GHz_03C120
DBID_REGIONAL_CPC_DURATION=0	0	0	0	0	0	0	0
mwan_lanNetmask=255.255.255.0
DBID_IDT_TIME=5	5	5	5	5	5	5	5
DBID_SIP_ANONYMOUS_SINGLE_CODE_DEACT=*82	*82	*82	*82	*82	*82	*82	*82	*82
DBID_ALARM_REPEAT_FRIDAY_EN=0
AckPolicy=0;0;0;0
DBID_PNP_FILE_NAME=
FixedTxMode=HT
websFilterDefaultPolicy=0
Lan2IngressRate=100000
DBID_SAC_CFWD_BUSY_ACT_VALUE=*90	*90	*90	*90	*90	*90	*90	*90
DBID_FUNCTION_KEY=1
wan_pppoe_user=
DBID_DIAL_CHAR=0	0	0	0	0	0	0	0
DBID_SETVOLUMN_SPEAKER=5
DBID_ST_NUM_FOR_REBOOT1=
DBID_SIP_ONLY_RSP_ONE_CODEC=0	0	0	0	0	0	0	0
DBID_SETVOLUMN_POWER=2
DBID_WEB_SSL_PORT=443
DBID_ST_NUM_FOR_REBOOT2=
DBID_SAC_CFWD_ALL_DEACT_VALUE=*73	*73	*73	*73	*73	*73	*73	*73
gkSnmpServerPort=
dhcpLease=86400
DBID_FORWARD_NUMBER=
MacFilterEnable=0
IEEE80211H=0
DBID_PREFER_MODE=0	0	0	0	0	0	0	0
SnmpKeepAliveEnable=1
DBID_CALL_UNPARK_CODE=
DBID_LCD_CONTRAST_LV=5
DBID_SAC_HOLD_CODE_VALUE=*77	*77	*77	*77	*77	*77	*77	*77
DBID_TR_CONNECT_USER_NAME=cnPilot R190W
DBID_SIP_RE_REG_INTERVAL=0.5	0.5	0.5	0.5	0.5	0.5	0.5	0.5
DBID_SIP_VMWI_RING_LEN=0.5	0.5	0.5	0.5	0.5	0.5	0.5	0.5
stpEnabled=0
DBID_SIP_REG_RETRY_INTERVAL=30	30	30	30	30	30	30	30
lostcarrier_timeout=300;300;300;300
DBID_TR_ACS_USER_NAME=WFVC05DSKTHS
DBID_SIP_CW_SINGLE_CODE_DEACT=*57	*57	*57	*57	*57	*57	*57	*57
DBID_WAIT_UIC_CALL_ACCEPT_TIME=24000
DBID_PROTOCOL_SEL=1
DBID_SAC_BLIND_TRANSFER_CODE_VALUE=*98	*98	*98	*98	*98	*98	*98	*98
DBID_DRL_MATCHED_DIALOUT_IMMEDIATELY=0	0	0	0	0	0	0	0
DBID_JITTER_THRESHOLD=50	50	50	50	50	50	50	50
mwan_ipaddr=
DBID_ENTER_FUNCTIONKEY_PASSWORD=0
WirelessMode=9
HT_MpduDensity=5
DBID_SIP_P_DEVICE_UID=
wan_l2tp_gateway=
DBID_SIP_PORT_GROUP_OUTBOUND=
WebInit=1
DBID_SIP_PREFER_PRIMARY_SERVER=0	0	0	0	0	0	0	0
DBID_SAC_DND_ACT_ENABLE=1	1	1	1	1	1	1	1
PktAggregate=1
mwan_lan_ipaddr=192.168.11.1
mwan_bridge_type=ip_br
DBID_DND_OFF_CODE=
DBID_ALARM_REPEAT_MONDAY_EN=0
DBID_RTP_STATISTICS_SERVER_KEY="apikey: eXrU0xv7PnjT56IoxpmWfF0MPzSPqeN1"
DBID_PRV_OPTION66_ENABLED=1
BsLan1Rate=255
DBID_UPGRADE_FTP_SERVER=192.168.100.121
DBID_ALTER_SIP_SMS_SERVER_IP=0.0.0.0	0.0.0.0	0.0.0.0	0.0.0.0	0.0.0.0	0.0.0.0	0.0.0.0	0.0.0.0
DBID_POLARITY_REVERSAL_ENABLE=0	0	0	0	0	0	0	0
DBID_OUTVOICE_GAIN_WITH_DB=-6	-6	-6	-6	-6	-6	-6
DBID_REMOTE_DSP_CLIENT_EN=0
NTPEnable=1
DBID_DNS_IP_ADDR=0.0.0.0
DBID_MIN_JITTER_TIME=20	20	20	20	20	20	20	20
DBID_RTP_ENCRYPT=0	0	0	0	0	0	0	0
WscEncrypType=1
DBID_VOL_HIGHLEVEL=7
DBID_TR_CWMP_ENABLE=1
CSPeriod=6
mwan_key_word=TR069_VOICE_INTERNET
DBID_SIP_ADD_ACCEPT_CONTACT=0	0	0	0	0	0	0	0
DBID_DISPLAYNAME_TYPE=0
DBID_SUBS_FAILED_RETRY_TIME_VALUE=
DETECT_PHONENUM_FUNC_ENABLE=0
DMZEnable=0
DBID_DMZ_STA_PORT=1024
DBID_IP_CHANGE_CHECK_DISABLE=0	0	0	0	0	0	0	0
FactoryDefaultsSetting=0
DBID_AUTOANSWER_DELAY_TIME=0	0	0	0	0	0	0	0
DBID_LOSS_THRESHOLD=10	10	10	10	10	10	10	10
RTDEV_EncrypType=AES
DBID_NOISE_CANCLE_DIRECTION=0	0	0	0	0	0	0	0
WscKeyMGMT=WPA-EAP
DBID_WEB_SIP_OUTBOUND_BACKUP=
DBID_SIP_AUTO_REDIAL_ACT=*66	*66	*66	*66	*66	*66	*66	*66
HT_PROTECT=1
DBID_REMOTE_DSP_SERVER_ADDR=
mwan_num=1
wan_dhcpv6_addr_settings=0
DBID_STUN_SERVER_PORT=3478
SNMPTrapCommunity=trap
DBID_R_CANCEL_KEY_CODE=R1	R1	R1	R1	R1	R1	R1	R1
DBID_RINGTONE2_T=
DBID_ALARM_REPEAT_ALLDAYS_EN=0
TxPower=100
DBID_SNMP_HELLOTRAPINTL=1800
Channel=0
SecurityMode=0
DBID_SIP_USER_TYPE=0	0	0	0	0	0	0	0
DBID_SIP_SERVER_HOSTNAME=
DBID_SIP_HOSTNAME_ENABLE=1	1	1	1	1	1	1	1
DBID_RINGTONE7_T=
HT_AMSDU=0
SnmpConfChecksum=7788520
RTDEV_DefaultKeyID=1
VLANEnable=0
NTPRetryTimes=3
DBID_ALARM_REPEAT_SUNDAY_EN=0
DBID_RING7_CALLER=
DBID_CONFERENCE_SER_NUM=
DBID_SAC_CFWD_NOANS_ACT_VALUE=*52	*52	*52	*52	*52	*52	*52	*52
HT_DisallowTKIP=1
DBID_SIP_TOS=46	46	46	46	46	46	46	46
DBID_ICMP_PING=0	0
DBID_SIP_INIT_REG_WITH_AUTHORIZATION=0	0	0	0	0	0	0	0
TxPreamble=1
AutoChannelSelect=1
DBID_CODE_FILE_NAME2=0
DBID_CALL_BLOCK_ENABLE=0	0	0	0	0	0	0	0
lan1_bind_wan_id=1
ipsec_psk=
DBID_SETVOLUMN_HANDSET=5
mwan_dhcpDnsMode=Auto
DBID_ENABLE_AUDIO_MB=1	1	1	1	1	1	1	1
DBID_CNG_DETECT_ENABLE=0	0	0	0	0	0	0	0
radvd_other_flag=1
DBID_TRAN_NUMBER=
FragThreshold=2346
ipv6_wan_pppoe_optime=5
lte_ndis_used=1
DBID_SIP_REG_INTERVAL=3600	3600	3600	3600	3600	3600	3600	3600
PrvUserAgentVal=
DBID_DAYLIGHT_SAVE=0
DBID_ET_ENCRYPT_DEPTH=10000	10000	10000	10000	10000	10000	10000	10000
DBID_ORG_UPGRADE_RULE=
DBID_SRTP_ENABLE=0
DBID_SAC_CID_ACT_ENABLE=1	1	1	1	1	1	1	1
DBID_RESYNC_RETRY_DELAY=3600
PARAMETER_VERSION=1.0.0
DBID_REFRESHER=0	0	0	0	0	0	0	0
wireless_connection_mode=AP
mwan_primary_dns=
DBID_METERING_AMP=350	350	350	350	350	350	350	350
DBID_T38_REDUNDENCY=0	0	0	0	0	0	0	0
DBID_HF_KEY_USAGE=0
cns_dhcp_43_url=
DBID_SIP_REGISTRATION_CODE=
DBID_DFLT_GW_IP_ADDR=
DBID_SIP_PORT_GROUP_SELECTE_PORT=0	0	0	0	0	0	0	0
HT_BAWinSize=64
DBID_A_ECHO_CANCEL_MGT=0	0	0	0	0	0	0	0
IPConflictDetection=Enable
idle_timeout_interval=0
DBID_DISPLAY_NAME=
DBID_INFO_DTMF_MODE=1	1	0	0	0	1	0	0
DBID_SAC_CFWD_ALL_DEACT_ENABLE=1	1	1	1	1	1	1	1	1
DBID_AUTOANSWER_MODE=0	0	0	0	0	0	0	0
WatchDogEnable=1
RADIUS_Server=0
DBID_REGIONAL_RING_BACK_T=440@-19,480@-19;*(2/4/1+2)	440@-19,480@-19;*(2/4/1+2)	440@-19,480@-19;*(2/4/1+2)	440@-19,480@-19;*(2/4/1+2)	440@-19,480@-19;*(2/4/1+2)	440@-19,480@-19;*(2/4/1+2)	440@-19,480@-19;*(2/4/1+2)	440@-19,480@-19;*(2/4/1+2)
DBID_SAC_CID_DEACT_VALUE=*85	*85	*85	*85	*85	*85	*85	*85
param_version_id=fwr8102_cambium-201811282037
DBID_ALARM_REPEAT_INTVL=5
cns_cloud_constat=1
HAS_AUTO_CONNECT_WIFI=0
mwan_pppoe_service_name=
NetSyslogEnable=1
DBID_SIP_MAX_RANDOM_PORT=60000	60000	60000	60000	60000	60000	60000	60000
DBID_RFC_PAYLOAD=101	101	101	101	101	101	101	101
DBID_SYS_BACK_LIGHT_TIMEOUT=0
DBID_SIP_UA_PROFILE_SUBSCRIBE_INTERVAL=3600	3600	3600	3600	3600	3600	3600	3600
AdminUser=admin
SyslogEnable=1
DBID_HOOK_PRIORITY=0
IPconflictInterval=600
DBID_DNS_MODE=0
DBID_ALARM_TIME=0
IPPortFilterEnable=0
dhcp6s_lease_time=86400
DBID_CFWD_ALL_OFF_CODE=
wan_l2tp_server=
SNMPRemoteLogin=0
DBID_CFWD_ALL_ON_CODE=
DBID_SIP_REGSUBS_ENABLE=0	0	0	0	0	0	0	0
DBID_SIP_PORT_GROUP_PICK_UP=*#	*#	*#	*#	*#	*#	*#	*#
DBID_RESYNC_PERIODIC=3600
DBID_CALL_PARK_CODE=70	70	70	70	70	70	70	70
DBID_AUTOCON_WIFI=0
DBID_REGIONAL_RING_OFFSET=0	0	0	0	0	0	0	0
ftpPassThru=1
DBID_CFWD_NOANS_ON_CODE=
DBID_RING6_CALLER=
DBID_REGIONAL_CPC_EN=0	0	0	0	0	0	0	0
DBID_PTIME_FOLLOW_REMOTE_SDP=0	0	0	0	0	0	0	0
DBID_DTMF_PTIME_EQ_RTP=1
DBID_SIP_SINGLE_PORT=0
DBID_ENTER_MENU_PASSWORD=0
SNMPTrapServerPort=162
MssMode=Auto
DBID_BITTEL_MENU_PASSWORD=
DBID_MEGACO_LOCAL_PORT=2944
DBID_RESYNC_FROM_SIP=0
wan_primary_dns=
DBID_GSMCALL_ENABLE_BY_CHANNEL=1	0
DBID_SIP_UA_PROFILE_SUBS_ENABLE=0	0	0	0	0	0	0	0
DBID_PROVISION_ENABLED=1
dhcpGateway=192.168.11.1
app_in_mwan=internet	sip	rtp	tr069	snmp	goahead	telnet	provision
internet_vid=2
ipv6_mwan_enable=1
DBID_NAT_TO_VPN=1
DBID_VPN_ENABLE=0
DBID_R_TIMEOUT_INTERVAL=1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1	1
HT_TxStream=2
DBID_PPPOE_LINK_STATUS=0
DBID_TIMEFORMAT_ENABLE=0
wan_pptp_pass=
ShortSlot=1
DBID_SIGTONE_TYPE=28	28	28	28	28	28	28	28
DBID_REGIONAL_CPC_DIRECTION=0	0	0	0	0	0	0	0
DBID_SIP_ANONYMOUS_CODE_ACT=*67	*67	*67	*67	*67	*67	*67	*67
arpFlowThreshold=64
radvd_prefix_life_time=3600
DBID_CODEC_LOOP_THRESHOLD=15	15	15	15	15	15	15	15
DBID_HOOK_FLASH_MAX=0.9	0.9	0.9	0.9	0.9	0.9	0.9	0.9
igmpEnabled=0
DBID_SIP_TELURL_ENABLE=0	0	0	0	0	0	0	0
TxRate=0
DBID_HTTP_PIN=admin
DBID_ALTER_SIP_SMS_SERVER_DOMAIN=
DBID_CALL_PDT_TIME=2	2	2	2	2	2	2	2
HT_BW=1
wireless_wan_gateway=192.168.0.1
mwan_vid=1
wlan2_bind_wan_id=1
DBID_ECHO_CANCEL_MGT=1	1	1	1	1	1	1	1
DBID_GSM_CALL_CODE=*99	*99	*99	*99	*99	*99	*99	*99
DBID_SIP_OPTIONS_TIMER_UNIT=3600
DBID_SOFTKEY_DND=0
PrvUserName=WFVC05DSKTHS
DBID_VAD_CNG_MGT=0	0	0	0	0	0	0	0
DBID_SEND_CANCEL=0	0	0	0	0	0	0	0
DBID_NEED_RESET=1
wireless_wan_netmask=255.255.255.0
LocalTelnet=0
WscConfMode=0
DBID_ALTER_SIP_SERVER_IP=
DBID_SIP_CID_ENABLE=1	1	1	1	1	1	1	1
DBID_PRV_ORDER_CODE=#*123
DBID_MEGACO_PRIMARY_MGC_PORT=2944
wireless_wan_primary_dns=8.8.8.8
RekeyInterval=3600;3600;3600;3600
dhcp6sMode=0
BsWanRate=255
DBID_RTP_PORT_END=50000	50000	50000	50000	50000	50000	50000	50000
DBID_MWITONE_DISABLE=0	0	0	0	0	0	0	0
DBID_AUTOCHANGE_INTERNATION_CALL=0
DDNSProvider=
DBID_AUTO_HOOKON_MODE=0	0	0	0	0	0	0	0
ipsec_enable=0
DBID_SIP_SERVER_IP=0.0.0.0	0.0.0.0	0.0.0.0	0.0.0.0	0.0.0.0	0.0.0.0	0.0.0.0	0.0.0.0
DBID_SIP_ANONYMOUS_CODE_ENABLE=1	1	1	1	1	1	1	1
DBID_PROFILE_RULE=
DBID_TRAN_NO_ANSWER_NUMBER=
DBID_SIP_AUTO_REDIAL_ENABLE=1	1	1	1	1	1	1	1
DBID_SIP_CALLBACK_CODE=*69	*69	*69	*69	*69	*69	*69	*69
DBID_SIP_PORT_GROUP_NAME=
DBID_LTE_SCELL_CODE=*80*	*80*
DBID_RING_MODIFY_ENABLE=1	1	1	1	1	1	1	1
ipsec_left_subnet=
APCwmax=6;10;4;3
DLSCapable=0
DBID_BELLCORE_STYLE_CONFERENCE=0	0	0	0	0	0	0	0
wan_pppoe_optime=60
WscSSID=RalinkInitialAP
wireless_wan_secondary_dns=8.8.4.4
NotBroadcastSSIDEmptyProbeAction=0
DBID_CALL_PEER_TO_PEER=0	0	0	0	0	0	0	0
BeaconPeriod=100
DBID_MEGACO_BACKUP_ENABLE=
DBID_ALARM_REPEAT_ONETIME_EN=1
DBID_EFFECT_STARTUP_SOUND=0
dhcp6s_server_preference=255
DBID_LCD_BACKGROUND=0
DBID_SIP_DIS_NAME=
wan_l2tp_ip=
DBID_REGIONAL_RING_VOLTAGE=45	45	45	45	45	45	45	45
goahead_vid=2
BsLan4Rate=255
DBID_HW_VERSION=101
DBID_DNSSRV_ENABLE=0	0	0	0	0	0	0	0
DBID_DND_ENABLE=0	0	0	0	0	0	0	0
DBID_SIP_ACCEPT_CONTACT_CONTENT=
dhcpEnabled=1
snmp_vid=2
DBID_LCD_BACKLIGHT_LV=7
DBID_SIP_CHECK_INCOMING_IP_ADDR=1	1
DBID_SETVOLUMN_BUTTON=2
DBID_AVT_MARK=1
DtimPeriod=3
DBID_SIP_SERVCE_TYPE=0
DBID_SIP_PORT_GROUP_ENABLE=0	0	0	0	0	0	0	0
DBID_SAC_CFWD_BUSY_ACT_ENABLE=1	1	1	1	1	1	1	1
DBID_ALARM_RING_INDEX=8
DBID_RESYNC_DELAY=14400
AccessPolicy0=0
AccessPolicy1=0
DBID_AUTOCHANGE_INTERNATION_CALL_NUM=00747
AccessPolicy2=0
lan_default_ipaddr=192.168.11.1
AccessPolicy3=0
radvdEnabled=0
DBID_RINGTONE3_T=
DBID_SIP_REGISTER_STATUS=0	0	0	0	0	0	0	0
DBID_DNSSRV_DOMAIN2=
DBID_UPGRADE_RETRY_DELAY=3600
HT_HTC=1
MssValue=1260
DBID_SPEED_DIAL2=
DBID_SIP_PORT_GROUP_OUTBOUND_PORT_BACKUP=5060	5060	5060	5060	5060	5060	5060	5060
DBID_SPEED_DIAL3=
DBID_RINGTONE8_T=
WebRemoteLegalIP=0.0.0.0
ipsec_trans_type=tunnel
DBID_SPEED_DIAL4=
tr069_vid=2
DBID_SPEED_DIAL5=
AutoChannelLimit=
DBID_SPEED_DIAL6=
DBID_SPEED_DIAL7=
DBID_CALLERID_COUNTRY_CODE=
DBID_BOARD_NAME=GIP2000
DBID_VPN_INITSRV_PORT=
DBID_SPEED_DIAL8=
DBID_SPEED_DIAL9=
mwan_pppoe_user=
DBID_SERVICE_ACTIVE_CODE_ENABLE=1	1	1	1	1	1	1	1
DBID_SIP_DIALPLAN_POLICY=0	0	0	0	0	0	0	0
BSSCwmax=10;10;4;3
Key3Type=0
DBID_SIP_SERVICE_TYPE=1
DBID_NTP_OPTION42_ENABLED=0
DBID_SIP_USE_VPN=0	0	0	0	0	0	0	0
DBID_LCD_TIME_FORMAT=1
DBID_SIP_SERVER_PORT=5060	5060	5060	5060	5060	5060	5060	5060
DBID_WEB_PORT=80
DBID_TRANSFER_ONHOOK_ENABLE=1	1	1	1	1	1	1	1
wan_ipaddr=
DefaultFirewallPolicy=1
PMKCachePeriod=10
HT_STBC=1
DBID_SIP_CODEC_PRIORITY=0	0	0	0	0	0	0	0
DBID_SIP_ALTER_ACCOUNT=
DBID_LCD_MENUSTYLE=1
DBID_SIP_PORT_GROUP_PROXY=
DBID_TR_MODULE_ENABLE=0
wan_pptp_gateway=
DBID_CED_DETECT_ENABLE=1	1	1	1	1	1	1	1
DBID_SAC_SPD_ACT_VALUE=*74	*74	*74	*74	*74	*74	*74	*74
mwan_lanDhcpType=1
dhcpMask=255.255.255.0
igmp_query_en=1
DBID_HEADSET_OUT_VOL=4
DBID_RINGING_TIME=60	60	60	60	60	60	60	60
DBID_RRTP_ENABLE=0
wan_pptp_netmask=
DBID_RTP_TOS=46	46	46	46	46	46	46	46
SNMPEnable=1
wirelessmode=0
TelnetPort=23
DBID_SIP_INVITE_USER_CHECK_ENABLE=0	0	0	0	0	0	0	0
mipsec_num=0
DBID_SIP_PING_ENABLE=0	0	0	0	0	0	0	0
DBID_WEB_SIP_OUTBOUND_BACKUP_PORT=5060	5060	5060	5060	5060	5060	5060	5060
DBID_TRAN_BUSY=0	0	0	0	0	0	0	0
DBID_WEB_IDLE_TIMEOUT=5
DBID_SIP_CALLER_ID_HEADER=0	0	0	0	0	0	0	0
dhcpSecDns=8.8.8.8
BSSACM=0;0;0;0
muti_wan_lan_map_enable=disable
MaxStaNum=16;16;16;16
DBID_VMWI_TYPE=0
wan_pptp_server=
DBID_KEYBOAD_LOCK_TIME=10
DBID_SIP_SMS_SERVER_PORT=5060	5060	5060	5060	5060	5060	5060	5060
DBID_TR_OPTION17_ENABLE=0
DBID_TR_CONNECT_PWD=cnPilot R190W
HT_EXTCHA=0
DBID_SIP_VMWI_ENABLE=1	1	1	1	1	1	1	1
DBID_EFFECT_MESSAGE_SOUND=0
DBID_PRV_CONFIGFILE=Cambium-cnPilot-R.cfg
DBID_SETVOLUMN_ALARM=4
lan2_bind_wan_id=1
DBID_SIP_SMS_SERVER_IP=0.0.0.0	0.0.0.0	0.0.0.0	0.0.0.0	0.0.0.0	0.0.0.0	0.0.0.0	0.0.0.0
DBID_PRV_PBK_RULE=
gkSnmpDoubleServer=
telnet_allow_ip=0.0.0.0
DBID_CFWD_BUSY_OFF_CODE=
DBID_RESYNC_ON_RESET=1
ipsec_left=
DBID_ALTER_VPN_ENABLE=0
DBID_DNSSRV_DOMAIN2_PORT=5060	5060	5060	5060	5060	5060	5060	5060
DBID_SIP_PORT_GROUP_OUTBOUND_BACKUP=
DBID_SIP_PORT_GROUP_TRANSFER_BY_ITSELF=1
RADIUS_Acct_Key=
DBID_LCD_CONFIG_PASSWORD=
DBID_SIP_INFO_TYPE=0	0	0	0	0	0	0	0	0
DBID_PPPOE_AUTO_DIAL=1
DBID_REG_USERAGENT_NAME=
lan_netmask=255.255.255.0
LoginSyslogEnable=1
DBID_BUSY_DELAY=5
wan_vlan_enable=0-disable
rebootMethod=0
DBID_SAC_CFWD_ALL_ACT_VALUE=*72	*72	*72	*72	*72	*72	*72	*72
DBID_REGIONAL_BUSY_T=480@-19,620@-19;30(.5/.5/1+2)	480@-19,620@-19;30(.5/.5/1+2)	480@-19,620@-19;30(.5/.5/1+2)	480@-19,620@-19;30(.5/.5/1+2)	480@-19,620@-19;30(.5/.5/1+2)	480@-19,620@-19;30(.5/.5/1+2)	480@-19,620@-19;30(.5/.5/1+2)	480@-19,620@-19;30(.5/.5/1+2)
DBID_CHECKSUM=7788250
APAifsn=3;7;1;1
DBID_SIP_DM_SHORT_TIMERVAL=1	1	1	1	1	1	1	1
DBID_FAILOVER_ENABLE=0	0	0	0	0	0	0	0
DBID_RING5_CALLER=
DBID_CALLEE_POLARITY=0
sip_vid=2
DBID_SIP_MWI_SUB_ENABLE=0	0	0	0	0	0	0	0
VLANName=
mwan_pppoe_optime=5
DBID_METERING_PULSE_EN=0	0	0	0	0	0	0	0
DBID_TR_PERIODIC_INFORM_ENABLE=1
NormalUser=user
SnmpTrapEventEnable=1
dhcp6sEnabled=0
DBID_HF_IN_VOL=5	5
WmmCapable=1;1;1;1
HT_GI=1
DBID_VIRTUAL_SERVER_LINE=
DBID_SIP_CW_SINGLE_CODE_ACT=*56	*56	*56	*56	*56	*56	*56	*56
RTDEV_CountryCode=US
RTDEV_Channel=0
DBID_SAC_CFWD_BUSY_DEACT_ENABLE=1	1	1	1	1	1	1	1
WdsKey=
gkSnmpIADSystem=
Lan3IngressRate=100000
DBID_ALTER_SIP_SERVER_HOSTNAME=
DBID_DIAL_PREFIX=
DBID_PPPOE_PWD=
TxAntenna=
DBID_ENCRYPT_KEY=
natEnabled=1
DBID_SIP_LOCAL_PORT=5060	5061	5062	5063	5064	5065	5066	5067
DBID_CFWD_BUSY_ENABLE=0	0	0	0	0	0	0	0
DBID_MEGACO_MGNAME=
swFastnatEnabled=0
DBID_SIP_URI=
RADIUS_Acct_Server=
DBID_VOL_LOWLEVEL=
CountryCode=US
DisableSSID=0
HT_BADecline=0
DBID_RAS_ENABLE=0
DBID_SAC_HOLD_CODE_ENABLE=1	1	1	1	1	1	1	1
WscNewKey=scaptest
SSH_SERVER_PORT=22
gkSnmpHeartbtCircle=
HT_BSSCoexistence=0
ipsec_conn_num=0
DBID_CALLERID_COUNTRY_CODE_REMOVE_ENABLE=0	0	0	0	0	0	0	0
Login=admin
DBID_SIP_HOLD_WITH_MEDIA_INACTIVE=0
SwPortVid=1,2,2,2,2
TxPowerPercentStyle=1
DBID_CALL_PICK_UP_CODE=
lan_prefix_len_v6=64
DBID_REGIONAL_RING_WAVEFORM=0	0	0	0	0	0	0	0
wan_l2tp_pass=
DBID_PACKET_CYCLE=1	1	1	1	1	1	1	1
DBID_R_CONF_KEY_CODE=R3	R3	R3	R3	R3	R3	R3	R3
BSSAifsn=3;7;2;2
DBID_REFRESH_TIME=0	0	0	0	0	0	0	0
RTDEV_AuthMode=WPA2PSK
DBID_T38_ENCRYPT=0	0	0	0	0	0	0	0
TxBurst=1
APACM=0;0;0;0
DBID_SIP_USE_OBSERVER_IN_DIALOG=0	0	0	0	0	0	0	0
ProvisionConfChecksum=7788520
RxAntenna=
BGProtection=0
DBID_SIP_CONTACT_PARAMTER=
mwan_dhcpLease=86400
DBID_PRV_TFTPSERVER=
DBID_SIP_CWCID_ENABLE=0	0	0	0	0	0	0	0
DBID_SIP_PORT_GROUP_PHONENUMBER=
IEEE8021X=0
DBID_FAX_BITRATE=14400	14400	14400	14400	14400	14400	14400	14400
DBID_BLFLIST_PICKUP_CODE=
gkSnmpEnable=0
WscAuthType=1
DBID_SIP_DNS_REFRESH_CHECK_TIME=0
wlan3_bind_wan_id=1
BsLan2Rate=255
DBID_TRAN_ALL_CALL=0	0	0	0	0	0	0	0
DBID_DTMF_VOLUME=-19	-19	-19	-19	-19	-19	-19	-19
DBID_SIP_KEEPALIVE_HELLO_PACKET_ENABLE=0	0	0	0	0	0	0	0
CountryRegionABand=7
DBID_SNMP_TRAP_LINKUP=1
DBID_RING4_CALLER=
DBID_IVR_PROTECT=0
Lan4EgressRate=100000
DBID_RANDOM_NUM=23456
DBID_DNS_IP_SECOND=0.0.0.0
DBID_DISABLE_CALL_SELF=0	0	0	0	0	0	0	0
DBID_DTMF_RTPEVENT_TOTAL_COUNT=24
RADIUS_Key=
wan_pptp_user=
SwPortAutoNego=Auto,Auto,Auto,Auto,Auto
DBID_MEGACO_RTPNAME_PREFIX=RTP
DBID_SIP_IPMODE=0
NintendoCapable=0
HT_RxStream=2
DBID_WEB_SIP_SERVER=
DBID_CONFIG_FILE_MD5SUM=
RTSThreshold=2347
DBID_RINGTONE_2=1
WirelessEvent=0
HideSSID=0
DBID_BK_KERNEL_ZONE=0
NoForwardingBTNBSSID=0
WscModeOption=0
WPAPSK1=[767a9530aa125d2d883638d4c4bd772b]
SNMPSetCommunity=[e9e9e1008dc999f3]
Password=[0bc4eaff102f256e]
RTDEV_WPAPSK1=[c760ba8ffe65c669]
DBID_NORMAL_WEB_PASSWORD=[76a38f541bd5654a]
SNMPGetCommunity=[a1c51277dc7cd5fa]
BasicPass=[0bc4eaff102f256e]
DBID_SUPER_WEB_PASSWORD=[0bc4eaff102f256e]
Here's the full configuration.  The channel is set to auto, but I changed it to 1, 6, and 11 with no luck.  The bandwidth was 20/40
Was there any resolution to this? We may be having the same issue with some of our R201P routers.
We are also seeing the same thing on our routers running 4.4.2
I talked to another large ISP in the northern half of the US.  He told me that they were changing out all of their R200 routers due to the devices giving the customers slow WIFI speeds.
He said they were installing some model of Ubiquiti Routers with WIFI, which gave the much better WIFI speeds to their customers.
He told me that they had a couple of hundred of R200 that they are in the process of changing out to the Ubiquiti Routers with WIFI and were sending the R200's that they were removing to the scapper for salvage.
Most likely the R200's will end back up in China being melted down.
See this thread. http://community.cambiumnetworks.com/t5/cnPilot-R-Series-Home-Small/R201P-Problems-with-WIFI/m-p/113550/highlight/true#M1985
Also see here. http://community.cambiumnetworks.com/t5/cnPilot-R-Series-Home-Small/R190V-R190W-Optimal-WiFi-Configuration/m-p/116653/highlight/true#M2085
Still testing, but these settings improve performance from what I can see. For now I'm not supporting A/B/G and only N or on 5ghz AC/AN. Then settings as follows:
  1. 2.4ghz on 20mhz channel only.
  2. Set "Operating Mode" to "Greenfields" on both 2.4ghz and 5ghz.
  3. Turn on A-MSDU on both 2.4ghz and 5ghz.
Pulling files from a NAS were snappier.
Other changes as mentioned before.
  1. Disable "DNS Proxy".
  2. Disable "Hardware NAT Enable".
  3. Disable "IP conflcit detection".
I haven't confirmed if IP conflict detection is working on firmware 4.6 but the others still seemed wonky after some quick tests.
Only difference in these changes is that the R190x routers don't have 5ghz or Hardware NAT.
Getting over 100meg on 2.4ghz in a 20mhz channel with the above changes. R201P. I will test one of the R190x's.
