hi… i want to connect my SM to swith/hub.
what is the crimping for my CABLE, is it STRAIGHT OR CROSSOVER ?
thanks
depends on if you connect with an autosensing switch, or a nonsensing hub. With auto it wont matter which you choose.
Most likely a straight through.
New Canopy modules auto-sense cable type.
oh ic… i’m currently using straight crimping.
thanks
i’ve posted this thred because i’m confused if the crimping of SM cable connected to PC is the same to the SWITCH>
With only two possiblities, trial and error should not be too frustrating…
