Any body knows why i can’t access my SM or even i cant ping my SM IP Address after it connect to my canopy AP?
i set my IP to local but still i cant access it.
try access it from AP,
Home - remote sessions
in this page, you can see all SMs connected to the AP, so you can reach it regardless IP configuration.
Once there, you can check ip, subnest mask, gateway and if SM can be reached local only or Public network.
When you lose control of sm once it connects to an ap , it means the management vlan is set and switched from the default to the one designated in management vlan,
Only happens on ap with vlans enabled,
