SNMP Documentation
I've looked through the support site and cannot find any manuals or documents besides the one for the firmware release notes. Is there anywhere documented with information for SNMP and OIDs for these cnPilot routers?
I was wondering the same regarding the E400.  With snmpwalk I can see all the interface stats in extreme detail, very nice.  But just ethernet stats, nothing on wireless.  Looking at the walk results I see "SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.17713.22" so I try walking .1.3.6.1.4.1.17713.22 but there are only three values, 1 2 and 0 respectively with no clue what they represent.
BTW, for both E400 and R200/R201 you can find the full user guide under the 'archive' tab - for some reason the only docs exposed as 'current' are the release notes.
j
Hi ,
I am sorry for inconvenience.
Please let me know you weather you need SNMP MIB information for cnPilot R200 or e400.
In cnPilot R200 all the OID's are not present in MIB , please let us know which OID's you need and we will try to add those OID's.
I was looking for information for cnPilot R200. Basically I wanted to see what could be configured through SNMP on these devices. I have no specific need at the moment. I am just looking into my managment options.
Thanks for the Information.
We will soon post updated R200 MIB on support site.
We are waiting for two years for this MIB....
Hi
Please refer User Guide Document(Page Number 117) to  configure the SNMP service and check the attached  the MIB file  to know  the supported  private OIDs
Please refer User Guide Document(Page Number 117) to  configure the SNMP service and check the attached  the MIB file   to know supported  private OIDs
User Guide Document Link: https://support.cambiumnetworks.com/files/r-series/
Regards
Niraj
