jvogel02
(jvogel02)
August 5, 2016, 10:05pm
#1
Trying to get firmware upgrades via an SSH session to work. Everyting I have found (which isn't much... Cambium doesn't seem to have published much on the subject) says that I should be able to do it.
I establish a SSH session, and issue the following command
(these are ePMP 1000 radios)
snmp set -v 2c -c MyWriteCommunity 127.0.0.1 .1.3.6.1.4.1.17713.21.4.7.0 s http://10.30.30.3/ePMP-GPS_Synced-v3.0.tar.gz
i get "Syntax error: Illegal parameter"
I have modified the above command every which way I can think of, but can not get it to work.
What am I missing?
Fedor
(Fedor)
August 8, 2016, 7:13am
#2
Hi, You have made typo “snmp set”. It shoud be “snmpset”. Also please clarify where are hou trying to run that command. Thank you.
jvogel02
(jvogel02)
August 10, 2016, 7:57pm
#3
I am running that command in the cli of the radio itself. I log in with SSH. On the radio's command line, there is no "snmpset". Context-sensitive help shows "snmp set" as valid.
Fedor
(Fedor)
August 11, 2016, 8:41am
#4
In case you are running this command in admin CLI it has correct format.
We had issue you have faced with in 2.6.2 FW.
It is already fixed in 3.0 Release, please try it.
Thank you.
newkirk
(newkirk)
August 11, 2016, 4:09pm
#5
I'm sorry, I couldn't stop laughing for a minute. The problem he's running into trying to update to 3.0 is fixed in 3.0, please try it? :)
j
Fedor
(Fedor)
August 11, 2016, 4:15pm
#6
Looks funny, but I hope all of us understood what I meant just to verify that FW upgrade via snmp is already fixed in 3.0 release.
Thank you.
no me funciona a mi tampoco y tengo la version del ePMP-NonGPS_Synced-v3.5.1.tar.gz
cambium deberia de documentarnos mas sobre este tema, ya que practicamente no hay nada sobre el.
