Hi
I was wondering if somebody had info as to where I an find the Mib files supporting the cnMatrix switches.
I’m looking to integrate them with our current Zabbix installation.
Chris
Hi
Chris
Hi Chris, the cnMatrix SNMP MIB files can be downloaded from this link.
The MIB filename is cnMatrix_MIB_Archive_502.tar.gz
Thank you - can you go into more depth as to which MIBS are most relevant. I noticed the cambium ones but not sure why they would be split up the way they are.
