SNMP to change device info?
I am wondering how can we update device name, description & other info using snmp? When I use a snmpset (via terminal), it doesn't seem to update device config. epmp gui continues to show the old name / info?
is it possible?
Thanks.
After making your desired config changes, one extra step is required - you have to snmpset the "apply changes" OID, like so;
snmpset -v2c -c$community $radioip .1.3.6.1.4.1.17713.21.4.4.0 i 1
This is equivalent to pushing "Apply" in the webUI. If a reboot is required, you may need to trigger that also.
If you push a complete .JSON configuration file to the device through the JSONCfgImport OID, the device will automatically apply/reboot as necessary.
Thanks anderp. What'd be the oid for triggering a reboot?
Looks like it should be .1.3.6.1.4.1.17713.21.4.1.0 based on the MIB file.
There's an online human-readable (but a bit out of date) version of the MIBs here: http://support.cambiumnetworks.com/framed/onlinetools/content.CAMBIUM-PMP80211-MIB.html
add a . before  the 1 and a .0 to the end of any given OID to snmpset it :)
Relevant MIB files are attached to every  ePMP Release.
https://support.cambiumnetworks.com/files/epmp/
Please use MIB browser to convert text values to numerical.
For example - Ireasoning MIB browser.
Thank you.
In those mib files, do you see a way to ADD an SNMP Trap server ip? I dont.
