Hello!
I’ve been tasked with writing a script to configure a bunch of APs to switch to using management VLANs, and due to various reasons I’ll be using SNMP.
my concern is. the moment I switch to a separate management VLAN, I’d lose access to the AP, do SNMP SET commands take effect immediately or do I have to use the Apply/Save SET commands too? Another thing I’ve come across is the RebootIfRequired OID, if I turn that off, will I be able to set all my changes and then save and apply them with a reboot?
