1: Is there a way to get Prizm to not be so dang case sensitive?
Searching for %chris% in Site Name will miss any SM labelled Chris, for example.
2: Is there a way to deal with accepting SMs via SOAP? I.e. an AP notifies prizm that a new SM is present, how do you programatically ‘accept and manage’ said SM?
3: The getElementPerformanceData give you min, max, average and total; is there a way to get actual values? That is, can I get all data, probably in five or ten minute increments depending on how Prizm is configured, for a given time period, which I can then feed to a grapher? Or would I have to generate a whole bunch of getElementPerformanceData requests for five minute spans?
- Search is case sensitive just like in Prizm GUI since it is directly wired to the database.
2. You have to use Prizm GUI to discover/accept SM for Management.
3. There are 3 API functions related to performance data. “getElementPerformanceData” returns summary data. Other two “getElementPerformanceFieldValues” and “getElementPerformanceValuesDelimited” return actual collected data for each time period.
1: Unfortunate.
2: That’s what I was afraid of.
3: Glory be, that could be EXACTLY what I’m looking for!
Thanks muchly!
