So what's the Plan for ePSK and WiFi7
Last time I checked… ePSK didn’t work with WPA3.
Is ePSK going to be supported in WiFi 7?
@Springs , yes we will have WPA3 support for ePSK with our Wi-Fi 6/6E and 7 APs. Launching beta in May timeframe.
While I don’t always “enjoy” beta testing. As long as its on my test bench and not in front of clients… if it needs to be done… I work on it.
I believe you have worked with Gary Hansen. I will ask him to reach out to you once the code is in a demoable form so that he can show you how it works first, so we don’t use too much of your time. Once it is available on Wi-Fi 6 APs, we can give you the code also so you can test it at your convenience. I am collecting early feedback from select customers. Appreciate your help!
do you need to link a mac address to the ePsk and wpa3?
I was never told… “Ok, this firmware includes it. Start testing.”
How is this going? I had heard the xPSK technologies were going to be a problem with WPA3, which is required for some bands and versions of 802.11.
I accidentally turned on WPA3 on my home system. Had to ask support how to turn it back off.
Was promised a remote session to show me “the new work flow” with WPA3 and ePSK.
Haven’t had a chance to do that session as I have a bug from several months ago I need fixed first
Hi Mike,
EPSK(Multipsk feature) can be used with WPA3. Need to follow epsk registraion flow for 6GHz band clients to work with EPSK. Refer user guide for more info epsk registration flow, starting on page 94:
Configure security as WPA2/WPA3-PSK or WPA3-PSK.
Add ESPK entry.
Connect with wlan passphrase.
Enter EPSK passphrase in redirection page.
Reconnect client with EPSK Passphrase.
Mac Linking is not required.
To answer the question…
It’s not going. The last firmware I got shut off my X7-v35.. I reported this and am awaiting replacement/replacements.
I have been stuck with Mikrotik caps-man for the last month.
So would any device connecting with the WLAN passphrase be forced to the redirection page and not allowed to proceed with out it?
Seems like you need a separate SSID for registration. One that jumps you to the captive portal to enter your passphrase. Once thats entered the system needs to send a file back to the client that loads into their WiFi profiles. Which should automagically connect you to the RIGHT SSID without any further action.
Yes. If securiy is WPA2/WPA3-PSK or WPA3-PSK then all devices connecting with the WLAN passphrase will be forced to the redirection page.
No. Seperate SSID is not required for Registration. Client connects to Access SSID with wlan passphrase, gets registered and reconnect with EPSK passphrase. This is one time activity.
The manual makes it sound like you have to delete the connection profile on the device then reenter the new password.
If that’s the case… I would highly recommend you figure out how to do it the way I described…
Connect to “Landing SSID”
Enter your EPSK into the portal.
Then a file downloads to your device with the connection profile.
Which loads to the device, so all they have to do next is select that SSID.
